zcpm.tgz
A compressed 512 MB diskimage, containing ZCPM for sd-card less or equal then 2GB. This image contains several utilities usable for Scrumpel7d on disk A:.
It can be booted by the CP/M boot command in the Z180 monitor.
x-gzip - 755.01 kB - 07/12/2020 at 08:01
Download
monz180rom.hex
This is an Intel-hex file that contains the monitor for Scrumpel 7d. This version is a revision of the previous Scrumpel monitor, It support Grant Searle CP/M boot, the LCD and DS3234 RTC. It has a RTC autodetect and temperature read-out. If no RTC is detected, all RTC related functions are disabled. The DEFAULT BAUDRATE is 38400 in stead of 9600 baud.
- 19.66 kB - 06/03/2020 at 05:06
Download
scrumpel7d.pdf
This is the Schematic diagram of Scrumpel 7d
Adobe Portable Document Format - 194.21 kB - 05/07/2020 at 04:35
Preview
scrumpel7dv12.zip
These are the gerber files needed for making a Scrumpel 7d PCB, Silk screen looks better with better text lay-out
application/zip - 235.13 kB - 05/07/2020 at 04:30
Download
