New version monz180rom.hex
08/05/2020 at 06:56 • 0 commentsNew hex file of monz180 uploaded. Issue with uninitialized stack solved.
Changed first startup instructions
07/18/2020 at 07:43 • 0 commentsThe LCD must be installed to run the monitor.
A 512 MB ZCP/M diskimage added
07/12/2020 at 08:27 • 0 commentsWith this image you can boot ZCP/M from a sd-card.
New version monitor uploaded. (V1.11)
07/06/2020 at 04:01 • 0 commentsNew functions in the Scrumpel monitor added. See new screenshots below. ATTENTION: Default baudrate is changed to 38400 baud.
Gerber files Scrumpel7d updated
06/17/2020 at 11:43 • 0 commentsI have the newest version of diptrace and I've generated a cleaner and nicer gerberfile.
Added more details
06/06/2020 at 08:04 • 0 commentsSome photo's added to illustrate the used modules.
Scrumpel7d monitor is now called monz180
06/03/2020 at 05:13 • 0 commentsThis is the final release of the monitor for Scrumpel 7d. This replace the previous version. The Intel-hex file can be loaded into your Eprom programmer to program the 27C256.
The monitor supports LCD, RTC DS3234 and Grant Searle CP/M boot.
To show the available commands press ? and a help screen is shown.Some information of the CPU
06/03/2020 at 04:58 • 0 commentsAdded default COM1 settings in startup.
Added components
05/11/2020 at 06:03 • 0 commentsExtra components added
Instruction updates
05/11/2020 at 05:38 • 0 commentsAdded instruction how to position the LEDS.
