Hackaday.io Hackaday.io
Sign up Log in
DIY 2D Plotter
2D Plotter Designed and Engineered from Scratch
travis-bumgarnerTravis Bumgarner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.1k views
2 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 8
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
1.1k
2
5
6
Team (1)
  • travis-bumgarnerTravis Bumgarner
Join this project's team
  • Twitch
  • YouTube
hardware
ongoing project
2dPlotter
This project was created on 05/10/2020 and last updated 6 years ago.
Description
I'm building a 2D Plotter one Twitch stream at a time. Follow me on Twitch to see updates live or check the recordings on YouTube. Links to YouTube and Twitch can be found under the external links section.
Project Logs
Collapse
  • Working X and Y! Also, created a paint program in Python!
    Travis Bumgarner • 07/08/2020 at 23:56 • 0 comments
    Today was an awesome day. I finally got linear motion working in both the X and Y direction. I also created a paint program in Python that can output its canvas to instructions for the 2D plotter. The end is getting closer!
  • Got both motors and switches working today
    Travis Bumgarner • 07/07/2020 at 18:27 • 0 comments
    I wired up the motors and switches to the Arduino. Then I wrote some basic code to control the motors and switches. Finally, I wrote a little script to make the printer head move repeatedly left - down - right - up.
  • Connected the 2D Plotter to receive commands from Python
    Travis Bumgarner • 06/24/2020 at 00:56 • 0 comments
  • Physical Assembly is Coming Together!
    Travis Bumgarner • 06/21/2020 at 00:02 • 0 comments
    The orders are slowly starting to arrive. I've also 3D printed all the parts. I was able to connect the first motor and wrote demo code to test its movement.
  • Parts are ready for Printing!
    Travis Bumgarner • 06/03/2020 at 00:03 • 0 comments
    Just loaded all the parts needed for printing into Cura. I'll be starting printing tonight or tomorrow! Come join me live on Twitch on Tuesdays as I stream: https://www.twitch.tv/travis_the_maker
  • Parts Ordered!
    Travis Bumgarner • 05/27/2020 at 22:51 • 0 comments
    I stream every Tuesday at 6PM EST. Come join me and don't forget to subscribe!
  • Circuit Prototype
    Travis Bumgarner • 05/16/2020 at 18:04 • 0 comments
    Today I decided to switch gears and setup a little circuit that would test all the components (2x stepper motors, input mechanism, screen, brain) that I'll need for the plotter. This was the result - a joystick that can increase, decrease and reset values; a screen to display the current value; and a stepper motor to position itself (0 = start, 100 = half turn, 200 = full turn) where that value is.
  • Day 2 Twitch Stream Update
    Travis Bumgarner • 05/11/2020 at 23:37 • 0 comments
    It looks like I made no progress, but I swear I did! I now have the foundation for motion in both directions. The first stepper motor (which controls the direction of the other stepper motor) will be with a threaded rod. The second motor will use a belt to move the painting apparatus (aka a pen, marker, etc.) around.
View all 8 project logs
Log In/Sign up to comment
Sign up with Github
OR
Dan Maloney wrote 05/11/2020 at 20:13 • point
Sounds interesting, hope you'll post a BOM here where you're done.
Travis Bumgarner wrote 05/11/2020 at 23:35 • point
Most definitely!
The 2015 Hackaday Prize
Custom electromechanical motor that can be printed using any 3D printer, some coil, maybe magnets and a controller.
Project Owner Contributor
3D Printed Parametric Motor
solenoidSolenoid
Voice-activated paper towel dispenser
Say Loudly: Dispense Towel
3megabytesofhotram3megabytesofhotram
A broken robotic chess game is easily turned into a CNC plotter. Can be cheap, depend on what you have.
CNC Plotter From Robot Chess Game
rocketburnsRocketburns
Egg shaped kid's toy that wobbles
Wobble
krockwellKrockwell
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY 2D Plotter", please tell us the reason.
Send message
Remove Member
