Hackaday.io Hackaday.io
Sign up Log in
DIY 2D Plotter
2D Plotter Designed and Engineered from Scratch
travis-bumgarnerTravis Bumgarner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.1k views
2 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 8
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
1.1k
2
5
6
Team (1)
  • travis-bumgarnerTravis Bumgarner
Join this project's team
  • Twitch
  • YouTube
hardware
ongoing project
2dPlotter
This project was created on 05/10/2020 and last updated 6 years ago.
Description
I'm building a 2D Plotter one Twitch stream at a time. Follow me on Twitch to see updates live or check the recordings on YouTube. Links to YouTube and Twitch can be found under the external links section.
Project Logs
Collapse
  • Working X and Y! Also, created a paint program in Python!
    Travis Bumgarner • 07/08/2020 at 23:56 • 0 comments
    Today was an awesome day. I finally got linear motion working in both the X and Y direction. I also created a paint program in Python that can output its canvas to instructions for the 2D plotter. The end is getting closer!
  • Got both motors and switches working today
    Travis Bumgarner • 07/07/2020 at 18:27 • 0 comments
    I wired up the motors and switches to the Arduino. Then I wrote some basic code to control the motors and switches. Finally, I wrote a little script to make the printer head move repeatedly left - down - right - up.
  • Connected the 2D Plotter to receive commands from Python
    Travis Bumgarner • 06/24/2020 at 00:56 • 0 comments
  • Physical Assembly is Coming Together!
    Travis Bumgarner • 06/21/2020 at 00:02 • 0 comments
    The orders are slowly starting to arrive. I've also 3D printed all the parts. I was able to connect the first motor and wrote demo code to test its movement.
  • Parts are ready for Printing!
    Travis Bumgarner • 06/03/2020 at 00:03 • 0 comments
    Just loaded all the parts needed for printing into Cura. I'll be starting printing tonight or tomorrow! Come join me live on Twitch on Tuesdays as I stream: https://www.twitch.tv/travis_the_maker
  • Parts Ordered!
    Travis Bumgarner • 05/27/2020 at 22:51 • 0 comments
    I stream every Tuesday at 6PM EST. Come join me and don't forget to subscribe!
  • Circuit Prototype
    Travis Bumgarner • 05/16/2020 at 18:04 • 0 comments
    Today I decided to switch gears and setup a little circuit that would test all the components (2x stepper motors, input mechanism, screen, brain) that I'll need for the plotter. This was the result - a joystick that can increase, decrease and reset values; a screen to display the current value; and a stepper motor to position itself (0 = start, 100 = half turn, 200 = full turn) where that value is.
  • Day 2 Twitch Stream Update
    Travis Bumgarner • 05/11/2020 at 23:37 • 0 comments
    It looks like I made no progress, but I swear I did! I now have the foundation for motion in both directions. The first stepper motor (which controls the direction of the other stepper motor) will be with a threaded rod. The second motor will use a belt to move the painting apparatus (aka a pen, marker, etc.) around.
View all 8 project logs
Log In/Sign up to comment
Sign up with Github
OR
Dan Maloney wrote 05/11/2020 at 20:13 • point
Sounds interesting, hope you'll post a BOM here where you're done.
Travis Bumgarner wrote 05/11/2020 at 23:35 • point
Most definitely!
Hackaday Prize 2020
WinDIYingThing is a side project that helped me to wind the coils for the generator that i'm using with "WinDIY" a 3D printed wind turbine
Project Owner Contributor
WinDIYingThing - Automatic coil winder
fabianFabian
Egg shaped kid's toy that wobbles
Wobble
krockwellKrockwell
A broken robotic chess game is easily turned into a CNC plotter. Can be cheap, depend on what you have.
CNC Plotter From Robot Chess Game
rocketburnsRocketburns
The 2015 Hackaday Prize
Custom electromechanical motor that can be printed using any 3D printer, some coil, maybe magnets and a controller.
3D Printed Parametric Motor
solenoidSolenoid
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY 2D Plotter", please tell us the reason.
Send message
Remove Member
