Changing Chips
05/19/2020 at 16:01 • 0 commentsI ran into a bit of a wall with the Arduino Uno. It turns out as much as it is easy to interface with the Pi Zero W it has the wrong chipset and won't allow me to run the Keyboard.h or Mouse.h libraries. A few nights ago I stumbled on to the Seeeduino Xiao which might have just made the project better. It is ultra small, inexpensive and comes equipped with the chipset I need. I will find out more when it comes in the mail.
Testing the Sensor
05/11/2020 at 13:53 • 0 commentsA typical Arduino IDE has a serial monitor but the CLI doesn't have that option. After doing some digging I found I was able to mimic the monitor by way of a cat command. I hooked up the ultrasonic sensor and ran:
stty -F /dev/ttyUSB* 1000000 raw -clocal -echo cat /dev/ttyUSB*
This allowed me to see in real-time what was going on with the sensor proving that they had interfaced properly. My next step is overlapping a keyboard with the sensor.
Connecting the Boards
05/11/2020 at 13:51 • 0 commentsI am farther along in this project than I expected. Last night I interfaced my Pi Zero W to my Arduino Uno via the adapter and cable with no power supply problems. The board itself reads correctly on the Raspbarian desktop due to the installation of the Arduino CLI. There's no Arduino IDE available on the Pi Zero W but the CLI does the job.
