FULL TRHOTTLE !
I wanted to use an IC engine as main power source from the very begining.
I chose a 196cc 4 800W (6.5hp) 4 stroke engine. It includes both manual and electric start. The engine is equipped with a centrifugal clutch, which simplifies my work a lot. It is a "LIFAN 168F-2D-B" engine.
VIDEO
closest servo : choke
other servo : throttle
TO BE CONTINUED....
