Major updates in Firmware
09/09/2020 at 21:15 • 0 commentsSome of the major updates in the firmware... (more to come) V1.35: - Fixed PID calculator coefficients and sampling (it could have had oscillations) - PID tested with 12V in and duty 110-220 with low and high resistance cable, acceptable performance in all cases - Missing to correct refresh rate of the screen (it is increased as the main loop is executed more times) V1.4: - Added channel tracking option in menu. Now it is possible to set one channel temperature, and both are set. V1.5: - Added AutoON function in menu: When changing tip, the channel goes on automatically to the set temperature. V1.6: - Buttons very responsive, including encoder switch - Some code cleanup
Software V1.3 and future updates
05/25/2020 at 07:44 • 0 commentsSoftware revision reached V1.3, main features:
- Programmable temperatures
- Duty cycle limitation (to use various power supply rating) programmable via menu
- Under Voltage Lock Out for lipo battery protection programmable via menu
Future implementations:- Small updated on UVLO implementation (mostly graphical)
- Channel tracking implementation
- More ideas? :)
Riccardo Pittini
