NEW LEDS arrived
07/08/2020 at 01:45 • 0 commentsNow we can have 9 watts of power for each wavelength of light. :)
OOPs, I think the regulator burned the leds, so time for a replacement
07/08/2020 at 01:42 • 0 commentsThe 5mm UC 395 nm LEDs for curing burned out, so I ordered some more that are larger and tollerant to small voltage fluctuations. So I will replace them
Putting it together and take some light box pics
07/08/2020 at 01:40 • 0 comments -
Rubberized coating
07/08/2020 at 01:38 • 0 comments -
Fitting the custom light reflector holder ring
07/08/2020 at 01:37 • 0 commentsIt has the website I made with has pictures of these projects up.
254nm UVC Germicidal light on by itself
07/08/2020 at 01:36 • 0 comments -
Adding switches
07/08/2020 at 01:35 • 0 commentsFitting the step up power supply to the LEDS and Bulb, but I need to wire in the two switches as well.
First try fail :(
07/08/2020 at 01:34 • 0 commentsThis was the first try for printing a ring, the ring was far too tight and after the test fit I could not pull it off and had to destroy it.
Measured for a custom 3d printed ring
07/08/2020 at 01:33 • 0 commentsThis ring holds to two case halves together and also holds the reflector in place in the tip of the flashlight. Here we are measuring for it.
Installing the First UV LEDS and UVC Bulb
07/08/2020 at 01:31 • 0 comments
