Th
The standard strap belt we used has a width of 20 mm and the thickness about 1 mm. You can find it in your local warehouse. Take the nylon one and if you cut it always use a burner to melt the ends.
Here you see how it is brought into the enclosure.
It is very compact and fits perfectly!
