![](https://cdn.hackaday.io/images/5089531590312237149.png)
Th
![](https://cdn.hackaday.io/images/6120821590312783795.jpg)
The standard strap belt we used has a width of 20 mm and the thickness about 1 mm. You can find it in your local warehouse. Take the nylon one and if you cut it always use a burner to melt the ends.
![](https://cdn.hackaday.io/images/7761901590313393909.png)
Here you see how it is brought into the enclosure.
![](https://cdn.hackaday.io/images/2342121590313615301.jpg)
![](https://cdn.hackaday.io/images/6069481590313631737.jpg)
It is very compact and fits perfectly!
