Three post-1982 pennies, sandpaper, and lots of elbow grease!
JPEG Image - 69.50 kB - 06/09/2020 at 00:20
Preview
The zinc core is peeping through
JPEG Image - 74.72 kB - 06/09/2020 at 00:20
Preview
Seven minutes later, the copper coating is almost gone
JPEG Image - 82.70 kB - 06/09/2020 at 00:20
Preview
Dropping a penny with exposed zinc core into household vinegar to estimate self-discharge rate for a Volta pile with that electrolyte (found to be weeks)
JPEG Image - 28.54 kB - 06/09/2020 at 00:20
Preview
Different sandpaper grit. There was no obvious winner.
JPEG Image - 22.41 kB - 06/09/2020 at 00:20
Preview
Handy separator material for the Galvanic cells
JPEG Image - 11.54 kB - 06/09/2020 at 00:20
Preview
Almost 1.7 V open-circuit voltage, or 0.55 V per cell.
JPEG Image - 62.89 kB - 06/09/2020 at 00:12
Preview
The penny Volta pile lights a red LED!
JPEG Image - 31.19 kB - 06/09/2020 at 00:12
Preview
The sandwiched pennies and separators make a Volta pile!
JPEG Image - 27.85 kB - 06/09/2020 at 00:12
Preview
Soak the separator in household vinegar
JPEG Image - 46.83 kB - 06/09/2020 at 00:12
Preview
Inside of Volta-pile ends. One is copper (positive end of battery), the other is zinc (negative end of battery).
JPEG Image - 69.12 kB - 06/09/2020 at 00:11
Preview
Leads soldered to outside of the Volta-pile ends
JPEG Image - 86.56 kB - 06/09/2020 at 00:11
Preview
Three pennies with the zinc core exposed on one side
JPEG Image - 80.65 kB - 06/09/2020 at 00:11
Preview
More separator trimming
JPEG Image - 36.11 kB - 06/09/2020 at 00:11
Preview
Cut the separator down to the diameter of a penny
JPEG Image - 27.66 kB - 06/09/2020 at 00:11
Preview
Folded coffee filter used as Galvanic-cell separator
JPEG Image - 20.82 kB - 06/09/2020 at 00:08
Preview
