Mod-less base station and 'blinkScript'
01/16/2021 at 18:39 • 0 commentsThe last few months I mainly worked on creating a custom script interpreter for 'syncBlink'.
All available script interpreters I used and tested had some limitations or I was not able to get it run on the ESP8266. Thats why I decided to write an own interpreter, because why not. At the same time I created a mod-less version of syncBlink which also exposes a web application. The web application provides the following features at the moment:- Switching Mods
- Setting WiFi connection
- Mod Editor
First version done!
06/24/2020 at 12:17 • 0 comments -
First version of Nodes firmware done!
06/20/2020 at 19:00 • 0 comments
Finally the Nodes firmware is done!I wrote a complete overhaul of the script engine which is now using mJS. I also implemented some API methods for the scripts. For example a "setDelay" method. With this method it is possible to delay the frequency updates.
The script in the video is using this method to create a running light which is syncronized beyond two nodes!
Base station done - Working on the Nodes now
06/09/2020 at 05:21 • 0 commentsThe base station is mostly done now. Here a small video of it:
I am now working on the Nodes. I hope I will finish the software part this week and the hardware in the coming week. The nodes will also use a Wemos D1 Mini which will scan for a available network.
Gerrit
