Introduction to KiCad and FreeCAD
HackadayU online course for PCB design using KiCad & mechanical design using FreeCAD. You need basic electronics / engineering skills.
Instructors anool-mahidhariaAnool Mahidharia
Thursday, September 24, 2020 12:00 am GMT Local time zone:
Register for thiscourse
FAQ
This course consists of 4 pre-recorded videos and 4 live office hours. More FAQ here.
Classes are pre-recorded and will be released Tuesdays at 19:00 IST/9:30a EDT/ 6:30a PDT. Office Hours are Fridays at 20:30 IST/11:00a EDT/ 8a PDT. Link to calendar for easy timezone conversion.
ABOUT THIS COURSE
This “Introduction to KiCad and FreeCAD” course will consist of byte sized pre-recorded video tutorials which will walk you from schematic capture onward to PCB and enclosure design. In recent years, the line between hobbyist and professional has blurred. Hobbyists are designing and assembling circuit boards with grain sized components on multi-layer boards and dense parts placements. And thanks to rapid prototyping, modeling enclosures to house the electronics it pretty easy as well. To become a skilled hobbyist / professional, it is essential to have these design skills. But EDA and CAD tools have a very steep learning curve, and its not easy to get started unless you have a lot of guidance along the way. So, join in, and improve your engineering chops by becoming proficient in PCB and mechanical design.
Why KiCad?
KiCad is an amazing Open Source (free as in freedom!) program that allows you to design your own printed circuit board without arbitrary limitations on board size.  KiCad offers an all-in-one solution:
  • Full featured EDA suite, GNU GPL license
  • Cross-platform - Linux, Windows, Mac OSX
  • Large, dedicated support community.
  • Extensive Documentation, FAQ's, Mailing List, Tutorials, IRC
Why FreeCAD?
FreeCAD is an open-source parametric 3D modeller made primarily to design real-life objects of any size. Parametric modelling allows you to easily modify your design by going back into your model history and changing its parameters.
WHO IS THIS COURSE FOR ?
This course is tailored for the electronic enthusiast who has just started off using KiCad or wants to switch to it from other tools. We will walk through a design from Schematic to Gerbers and answer your “how-to” questions.
Later, we will have a  quick introduction to FreeCAD, learning how to model an enclosure after importing a 3D model of the finished PCB.
All you will need is a basic understanding of electronics and mechanical modelling.
COURSE CONTENT
Here’s how we will progress over the next four weeks.
Week 1 :
Essential KiCad links, discuss KiCad best practices, setup a project directory tree, do a schematic capture, understand symbol library management and create custom symbols
Week 2 :
Symbol<>Footprint association, essential PCBnew plugins, PCB layout, footprint library management and creating custom footprints, adding non-technical layers to help production and assembly
Week 3 :
Engineering/Manufacturing outputs - GERBERS, vector graphics, 3D CAD formats. BoM management, creating and adding graphics such as logos to the PCB
Week 4 :
Essential FreeCAD links, FreeCAD basics, essential workbenches, unifying KiCad and FreeCAD via the KiCad StepUp tools workbench, PCB import, simple enclosure design, Exporting for manufacturing
PREREQUISITES
On your Person, all you need installed is some basic electronics and engineering knowledge, and some drawing skills.
On your computer, you will need to install the two programs, along with some add ons.
  • FreeCAD workbenches : KiCad StepUp Tools, Exploded Assembly, Fasteners, Manipulator, Sheet Metal
    • To activate Workbenches, go to TOOLS > ADDON MANAGER
  • KiCad + FreeCAD Class 1
    Lutetium07/07/2020 at 16:54 0 comments
    Here is the link to watch Class 1.
    In this class, we cover:
    00:00:32 - Schematic walk through
    00:03:28 - Project Manager overview
    00:05:05 - EEschema, toolbar review
    00:12:00 - Start schematic process
    00:13:20 - Place parts
    00:18:50 - Place wires / connections
    00:21:35 - Place Net labels
    00:45:00 - Hierarchy Sheets
    00:55:55 - ERC and Power Flags
    01:00:30 - Libraries - backup, create, edit parts
    01:09:55 - Wrap up Session I
    See you in the Office Hours Friday!
  • KiCad + FreeCAD Class 1 NOTES
    Anool Mahidharia07/07/2020 at 18:47 2 comments
    Additional Notes for Session 1 : KiCad + FreeCAD
    GIT REPO
    Here's a link to my GIT repo for review.
    https://github.com/wyolum/HackadayU_KiCad_FreeCAD
    VIEW FOOTPRINT IN SCHEMATIC LIBRARY BROWSER
    In EEschema Library Browser, if you see only the schematic symbol but not the footprint, check this setting :
    PREFERENCES > PREFERENCES > Eeschema > Show footprint previews in library browser (check)
    USE REPETITION FOR SPEED
    If you have a bunch of repetitive actions to be done, such as placing incremental net labels, or the same length of wire connected to a succession of pins on an IC, then
    • Set up Repetition parameters in PREFERENCES > PREFERENCES > EEschema
      • Set Horizontal pitch of repeated items
      • Set Vertical pitch of repeated items
    • Place the first item (net label, wire etc).
    • Hit the “Insert” key and the item you placed will be repeated according to the parameters set in Preferences. If it’s a Net Label, it will also increment each time you “Insert”.
    • Here’s a short video showing how it works.
    BUSES
    We looked at a super simple example of how busses can be used, it wasn’t exactly an appropriate use of the feature, since the same result can be achieved just by using Net Labels. But for example, if you have a more complex circuit, where there is a 16-bit data bus on a micro-controller labelled PD0..PD15, that needs to be connected to a memory device with 8 pins labelled ADR0..ADR7 and the other 8 pins labelled DAT8..DAT15, then the BUS feature solves the problem.
    • Add wire stubs and bus entries on the first device (use the repetition feature to speed things up).
    • Add wire stubs and bus entries on the second device
    • Add net labels on the first device – PD0 to PD15
    • Add net labels to the second device – ADR0 to ADR7 and DAT8 to DAT15
    • Draw a bus that connects all of these pins
    • Add a net label near the first device – PD[0..15]
    • Add a net label near the second device – ADR[0..7]
    • Add a third label near the second device – DAT[8..15]
    The pins then get connected like so :
    PD0 > ADR0
    PD1 > ADR1
    PD7 > ADR7
    PD8 > DAT8
    PD9 > DAT9
    PD15 > DAT15
    Here's a screenshot of how that looks
    IGNORE SCHEMATIC SYMBOL
    If you'd like to add a symbol on the schematic which should not be placed on the PCB, then add a "hashtag" to it's REFERENCE (example - #U4 instead of U4, and it will not be put on the PCB)
    This can be used to show where off-board parts such as a Motor, Fan, Solenoid etc connect to a screw-connector on the board, for example.
    KiCad CHEAT SHEET
    Handy KiCad cheat sheet for reference, in several languages
    https://github.com/KiCad/kicad-doc/tree/master/src/cheatsheet
    And here's the link to the KiCad forum if you'd like to give feedback to the author
    https://forum.kicad.info/t/cheatsheet-for-kicad/5247
  • KiCad + FreeCAD Class 2
    Anool Mahidharia07/13/2020 at 19:12 0 comments
    Here is the link to watch Class 2.
    In this class, we cover :
    00:00:00 - Session II Overview and Session I review
    00:04:15 - Bitmap to Component converter
    00:09:40 - Symbol - Footprint association
    00:15:20 - Create footprint library and import/add custom footprints
    00:17:50 - Netlist Export
    00:18:50 - PCBnew Toolbar review, layer manager, page, board and grid settings
    00:25:10 - Netlist / Parts Import
    00:28:00 - Parts - move, rotate, flip, place
    00:34:10 - Board outline / Edge cuts
    00:43:00 - Routing / Track layout
    00:43:40 - Net classes setup
    00:53:45 - Zone / Pour / Fill
    01:02:45 - 3D View
    01:03:05 - Silk and Fab Layer cleanup
    01:10:15 - ERC
    See you in Office Hours on Friday - note the revised time - at 20:30 IST / 11:00am EDT / 8:00 am PDT.
    I've updated the Git repo to reflect what we've covered in Session 2.
    If you have any questions, please let me know here.
  • KiCad + FreeCAD Class 3
    Lutetium07/20/2020 at 19:10 0 comments
    Here is the link to watch Class 3.
    00:00 Intro
    02:20 Dimensions, Origin offsets
    05:30 Interactive Routing
    06:55 Modify edge cuts
    10:15 Archive footprints in custom library and swap references
    16:15 Keepout Areas, Exposed zones
    23:45 Plugins
    31:20 Interactive BoM
    33:20 Plotting - Gerbers, Position files and PDF's
    39:45 GerbView
    42:30 Export - STEP and VRML
    46:30 Create custom footprint and add to project library
    55:20 Back import
    57:00 Add 3D model for custom footprint
    59:55 Interactive Routing - Advanced features
  • KiCad + FreeCAD Class 2 Q&A
    Anool Mahidharia07/21/2020 at 20:15 0 comments
    Class 2 Office Hours Q&A:
    Here are the Questions (and answers) from the Class 2 Office Hours Q&A
    • Was there a reason to place the Neopixels closer to the edge of the board instead of the mounting holes? I would think that placing the mounting holes closer to the corners would be preferable.
      • The plan is that when we make the enclosure in FreeCAD, the main circuit board (area within the mounting holes) can be enclosed, while the part with the RGB LED’s can stick out / be exposed.
    • If in-case, my logo size or the layer is wrong, how do I change those parameters?
      • There’s no easy way, other than going back to Bitmap to Component converter, and regenerating the symbol / footprint all over again.
    • I’m pretty bad with electronics. I notice that between the end of Class 1 and the start of Class 2, the schematic has changed, which is throwing me off, because I don’t know the missing steps that got from version 1 to version 2. Specifically, I now see a box around the connectors at the end of the LED chain. But, more importantly, when I was watching you assign footprints, you have a “5V” (J4) that I do not have…
    • UPDATED: I’m guessing you customized the connectors to add boxes around them. And changed the power supply, changing the female connector to male, and adding a female connector between the end of the Class 1 and the beginning of Class 2.
    • My default in Board setup is quite different from yours. (I’ve never used it before, so this is what it installed with):
    Clearnc
    Track Width
    Via Size
    Via Drill
    uVia Size
    uVia Drill
    dPair Width
    dPair Gap
    0.2 mm
    0.25 mm
    0.8 mm
    0.4 mm
    0.3 mm
    0.1 mm
    0.2 mm
    0.25 mm
    UPDATED: I did not know mil as an imperial unit. I see now that the above values are the metric equivalents -- or close to -- the mils shown in your defaults.
    • Try changing the project “Units” to INCH instead of MM. In Schematic/PCBnew, the second and third toolbar icons toggle between these two.
    • Then, in PCBnew > BOARD SETUP > DESIGN RULES > NET CLASSES , you can set it up.  I’m posting my project files on Github, so you can clone that repo, and compare.
    • https://github.com/wyolum/HackadayU_KiCad_FreeCAD
    • In Board Setup, when you are changing the widths of the routing, I see you have /A1, /A2, /A3, /D1, and /D2. Mine does not have those labeled that way. When / how did that happen?
      • I wanted to show how the BUS function works, so I made some changes to make that clear and renamed the nets. Actually, I made some more changes, so best to clone my version from the repo (see link above) and let me know if you need help to replicate my version.
    • My SPI PROG footprint is “backwards” with pins 1, 3, and 5 at the top. I hope the right thing to do was to mirror it in the Footprint Editor, save as tiny_blinky, update the Symbol Fields in Eeschema, and change the footprint in Pcbnew… It now looks like yours…
      • Ummm, Prolly. Did you try ROTATE / MIRROR / FLIP (X/Y) options within Schematic itself ? Maybe if you share a screenshot, we can sort it out.
  • KiCad + FreeCAD Class 3 Q&A
    Anool Mahidharia07/24/2020 at 17:48 0 comments
    Class 3
    • When setting the origins, how close is “close enough”? The center of my board, mathematically is 1.4375 inches by 0.8 inches. However, the closest I could get seemed to be 1.4350 (or 1.4400) inches by 0.8 inches. (ubuntourist)
      • Set your Grid Size to 25 mil instead of 50 mil
      • OR
      • Block Select All (make sure to enable all layers first) > Secondary click > Move Exactly (hotkey ctrl + M) , set X coordinate to -0.0375 > OK
      • This’ll move the board to X=1.4 and Y = 0.8
    • Racing to finish… Still 15 minutes left in the video. I see your Oshpark display of your part is much more detailed than mine… I mean, the detail that I see in the files that I’ve zipped up and submitted gets lost in translation… (ubuntourist)
      • Well, WYSIWYG,
      • Ah, gotcha. I know what that is. I ran into this error last week, and have a temporary fix until OSHpark fixes it. If your edge cuts layer line thickness is less than 4 mil, OSHpark render fails. If the line thickness is 4 mil or more, it works.
      • Make sure your Board Edge Cuts layer graphics thickness is at least 4 mil or more.
      • Go to EDIT > Edit Text and Graphics Properties, (see image below)
    • I am getting an error while creating the step file. It says “Unable to create STEP file. Check that the board has a valid outline and models.”......... I have already drawn it three times...any tips to avoid the error in the future or any idea how I can debug the current edge cut of the board?
      • Error is what it says - the board outline has a discontinuity. Sometimes, if the discontinuity is large enough, KiCad will complain when you try 3D view.
      • If discontinuity is very minute, 3D will work, but STEP will fail
      • Fix your Edge Cuts layer graphics to fix this. There should not be any discontinuities in the outline. This usually occurs if you have set a very fine grid size (such as 1 mil instead of 10 mil), and the end points of two consecutive elements do not line up and are not coincident.
    • In my KiCAD installation, my right-side toolbar doesn’t show all the functionalities like in the video. How can I adjust the toolbars. I faced this problem both in Eschema and PcbNew. I searched online but didn’t find anything.(Aditya)
      • Can you post a screenshot ? What parts are you missing ?
      • Looks like ICON scaling issue.
      • KiCad > PCBnew > Preferences > Common > User Interface > Icon Scale
    • Also, when we do the pcb page setup, how do you decide which layers you need or don’t need?(Aditya)
      • Depending on number of copper layers, you need
        • all the copper layers
        • Top/Bot Mask
        • Top/Bot Silk
        • Edge Cuts
        • .DRL drill file
      • For getting a solder paste Stencil made, you need
        • Top/Bot Paste
      • For board assembly you need
        • .POS files (FILE > Fabrication Output > Footprint Position Files
        • Top/Bot Adhes (adhesive) - but not always necessary (most board houses auto-generate this from the other layers)
        • Top/Bot Fab (fabricate) layers can be helpful too, in addition to 3D images in various orientations for visualisation
    • This is a bit off the class scope. I came across the PCB Motors on Hackaday’s blog last year. They were made by Carl Bujega. I noticed on his youtube channel that he uses Altium to not just design PCB motors, but also flexible PCBs. I wanted to know if something similar to that is possible to replicate on KiCAD.
      • Rigid or Flex PCB is not a problem at all - as far as KiCad is concerned, the only difference is in the board thickness, everything else stays the same.
      • But you may need extra plugin’s to design helical coils and such for the motor “windings”. Just look for appropriate plugins as needed.
  • KiCad + FreeCAD Class 4
    Anool Mahidharia07/29/2020 at 19:04 0 comments
    Here is the link to watch Class 4.
    https://www.youtube.com/watch?v=lbnrUtgFFCc
    00:00:08 - Session Overview
    00:00:20 - FreeCAD walk through, Preferences, Addons and Addon Manager, Customise workbenches
    00:03:05 - Part workbench, working with primitives
    00:04:00 - Navigation, mouse control
    00:09:00 - Sketcher Workbench
    00:17:00 - Part Design workbench
    00:26:00 - KiCad StepUp Tools workbench - Edge Cuts layer push / pull
    00:38:00 - KiCad StepUp Tools workbench - PARTS push / pull
    00:46:45 - STEP model manipulation
    00:56:50 - KSU WB Footprint / 3D model alignment and export
    01:04:10 - Review, Part workbench Shape Binder quick overview, Session wrapup
  • KiCad + FreeCAD Class 4 Q&A
    Anool Mahidharia07/30/2020 at 14:45 0 comments
    Class 4
    • At 14:39 in the video, after constraining the internal rectangle sketch, while you are still in the sketch workbench, your video shows the outline sketch (Sketch001) on the top face of the Extrude part. I cannot see that in my version. All I see is the Extrude part, even though the Combo View shows me all the data and view information for both Extrude and Sketch001. The sketch lines are invisible. How do I make it visible?
    • What do you see in the wireframe mode? Did you select top face of "extrude" first, then start the second sketch, making sure you use "sketch attachment - flat face" ?
    • Ah, I see the error in the file link you sent me. The sketch you have drawn shows up in line color “blue”. This means those four lines of sketch001 are “construction lines” - which I didn’t cover in the video. Construction lines are drawing aids you use to help make sketches, but which are not part of the real sketch. So think of them as “virtual” reference elements to help you create a sketch. To toggle between regular sketching and virtual “construction mode” sketching, use the last icon in the Sketcher “drawing tools” toolbar.
    • Ah. Done. Thanks.
    • Sir, when I am trying to import the kicad_pcb file, only the base board loads up. I am giving the screenshots of the error messages. Also I verified the 3D package path and it’s correct in both KICAD and FreeCAD.
    • Your KISYS3DMOD needs to be usr/share/kicad/modules/packages3d
    • Make sure you’ve set this correctly in KiCad and in FreeCAD KiCadStepUp tools Preferences.
    • Make sure you have the latest library downloaded from the KiCad github repo.
    • Use this URL : https://github.com/KiCad/kicad-packages3D
    • It’s likely you’re missing all the models. For example, search for SOT-223.wrl and SOT-223.step (or SOT-223.stp) - you ought to have both available in the “Package_TO_SOT_SMD.3dshapes” folder.
  • LINKS
    Anool Mahidharia07/30/2020 at 18:54 1 comment
    Adding all links in a single Project Log - work in progress.
    If you spot a mistake or there's a missing link, please let me know.
    PROJECT
    PROGRAMMING
    If you physically build this project, here are some links you can use to figure out how to program the ATtiny
    KiCad
    FreeCAD
    3D CAD MODELS
View all 9 course classes
Enjoy this course?
Ken Yap wrote 02/27/2025 at 07:14 point
KiCad 9 was released recently. This course is now 4 versions behind.
Catonline wrote 11/28/2024 at 11:38 point
Link in KiCad instructions directs to some shady website.
use instead kicad.org
KiCad ver  : https://kicad.org/download/
KiCad Libraries : https://kicad.org/libraries/download/
Schematic, Footprint, 3D models, Templates
Richard Hogben wrote 11/28/2024 at 14:32 point
Thanks will try to fix these
Anool Mahidharia wrote 11/29/2024 at 19:36 point
Thanks for pointing this out ! I've fixed the links.
Ken Yap wrote 01/23/2024 at 12:01 point
KiCad 5.1! You'll soon be 3 versions behind. Either do a new course for KiCad 8 any day now or advise people a lot of stuff in this course is out of date.
Eduardo Chancay wrote 10/18/2020 at 23:56 point
Where could I find videos for sessions?
Look Right wrote 01/22/2021 at 20:33 point
I searched them also and I found it: https://github.com/Ekran/HackadayU_KiCad_FreeCAD
ubuntourist wrote 07/25/2020 at 15:43 point
Know anything about "the competition" -- Horizon EDA (https://horizon-eda.org/)?
I found it whilst stumbling around looking for something else.
In my near complete ignorance, it looks "interesting" and seems to have been getting recent love in terms of continued development work but I don't know if there's any real buy-in from the community.
Anool Mahidharia wrote 07/28/2020 at 11:07 point
Saw it a while ago, but haven't had a chance to check it out yet. It's on my to-do list.
AdityaPrakash23 wrote 07/25/2020 at 11:51 point
Hello Sir!
In yesterday's office hour, you mentioned you would put the links related to KICAD action-plugins and templates on this page. Could you please share the links? I would love to try out the amazing templates that you showed!
Anool Mahidharia wrote 07/28/2020 at 11:21 point
Will add a comprehensive LINKS project log, but in the mean time, here's a link to the Templates :
https://github.com/KiCad/kicad-templates
https://kicad-pcb.org/libraries/download/
https://github.com/kicad
https://kicad.github.io/
HTH !
duwahdiddy wrote 07/25/2020 at 04:11 point
I would like to see one more class that talks about setting up Kicad with all of the footprints. I downloaded the footprints and installed them. But later I found out you appear to have to load them manually one at a time?
When the board was completed in Class 2 I did a 3D view of my board and the Capacitors were drastically larger than what their footprint in 2D shows. I'm sure it had something to do with mapping the 2D footprint to the correct 3D footprint.
In my footprint library I see Capacitor_THT.pretty and Capacitors_THT.pretty. When I added my capacitors I used the Capacitors_THT reference. I later noticed that you used the Capacitor_THT reference...so I changed it. But still no luck. The 3D view shows the wrong size capacitors.
Everything else looks OK. I'm just a bit lost as to why my libraries are so screwed up. The class time at 8am on Friday is bad for me. I have a meeting every Friday for work.
Perhaps you can add this to the 1st class in the August time slot, i.e. the 2nd round for this class. I will gladly sign up again to get more information. Your class is awesome.
Anool Mahidharia wrote 07/28/2020 at 11:19 point
Thanks for the feedback. Have you done a fresh git repo clone of the libraries ?
Schematic symbols: https://kicad.github.io/symbols
PCB footprints: https://kicad.github.io/footprints
3D models: https://kicad.github.io/packages3d
Templates : https://github.com/KiCad/kicad-templates
I recommend you do a fresh download to an empty folder, and reassign the paths in KiCad for symbols, footprints and 3D packages.
If you can't attend office hours, just add you questions to the Q&A doc on Google [ https://docs.google.com/document/d/1oJc1sW4ZMSlCw0z1culPuzAjrDhr_zM8GoafmbaMEL0/edit ] and I'll add an answer.
The Q&A doc is also added to as Project log so everyone can check it out.
Morberis wrote 07/15/2020 at 17:47 point
Thanks for putting this on.
Anool Mahidharia wrote 07/15/2020 at 19:45 point
Thanks !!
Lutetium wrote 07/07/2020 at 16:53 point
Hi everyone and thanks for joining us in Kicad + Freecad.
We provided the pre-recorded video in advance so that people could learn at their own pace. Sorry that wasn't clear in the ticketing site. Bear with us while we get this program off the ground. There will be a live Office Hours on Friday where you can ask questions.
-If you'd like a refund because you didn't get what you were expecting, please request one through the ticketing site.
-If you enjoyed the class, let us know!
-Feedback is welcome, superconference@hackaday.io.
ubuntourist wrote 07/07/2020 at 15:44 point
Last night, I went through the tutorial and ended up with nice pretty PDF's of the schematics as shown in the video. (Took me bloody forever, since I'm very new to this and have zero electrical engineering chops.)  But I'm religious about taking notes and have a nice README.md (and corresponding README.pdf) with my notes. Two questions / comments though:
According to dpkg I have kicad 5.1.6-202005120818+c6e7f7d~86~ubuntu20.04.1, which would seem to satisfy the "5.1.6" prerequisite. However, I noticed two differences:
1. When selecting a part from the symbol library, the video shows both a schematic image, and underneath that a... footprint? I think. Mine does not show the footprint thingie. Is that an option I can set or do I really need to download yet another non-integrated version of application? (I really hate doing that, and may just end up living without the preview.)
2. The other minor difference: When moving the ATtiny to make room for the bus, in the video, only the wires for pins 2 and 3 "broke". In my version, the pin 8 wire broke at the junction for the SW1 switch. Not a big deal. Just a comment.
Anool Mahidharia wrote 07/07/2020 at 16:21 point
Hi @ubuntourist , way to go !
1. In EEschema, can you go to PREFERENCES > PREFERENCES > EESCHEMA > Show footprint reviews in symbol chooser (enable)
2. That could be due to how the block was selected. Also, after selecting the block, did you choose "move" or "drag" ?
ubuntourist wrote 07/07/2020 at 16:37 point
Thanks.
1. I looked but missed it the first time. I now have footprint preview enabled.
2. I chose "move"... I think. 😉
Also. One more quick question: I'm guessing that the downloaded symbols, footprints and packages3D include everything that was already in the stock Debian package. Yes?
(I downloaded and unpacked them a few weeks ago, but I didn't want to screw up the existing default paths "/usr/share/kicad/..." nor overwrite the files that are managed by dpkg. In any case, using the files in /usr/share/kicad/ seemed to work okay last night...)
Anool Mahidharia wrote 07/07/2020 at 17:00 point
Answer to your new Q - Yes,
I recommend cloning the three repos locally, and keeping them updated frequently.
But if "usr/share/kicad/.." works for you, then whatever floats your boat.
ahmed.asaleh2 wrote 07/07/2020 at 15:23 point
Unfortunately there is no live event, they just posted a pre-recorded YouTube video with a very, very bad quality. I hope they'll fix it on the next week.
Anool Mahidharia wrote 07/07/2020 at 16:13 point
I'm sorry you had an experience lower that your expectations. Do you have feedback that can help us improve ?
ahmed.asaleh2 wrote 07/07/2020 at 13:36 point
no one is starting the zoom meeting! Why? I've been waiting for more than 5 minutes.
ubuntourist wrote 07/07/2020 at 14:20 point
I thought I had saved a link to the zoom meeting, but then could not find it anywhere, and assumed I must have seen it on a page that was later edited to remove it. I would not have gotten up so early had I known there was no live event.
ahmed.asaleh2 wrote 07/07/2020 at 15:21 point
Yes indeed, I hope that won't happen next time.
Anool Mahidharia wrote 07/07/2020 at 16:10 point
Sorry about that, @ubuntourist !
We felt releasing a pre-recorded video will allows everyone to follow their own pace, instead of trying to keep pace with a live video. Anyhow, there's the live Q&A session scheduled for Friday.
ahmed.asaleh2 wrote 07/08/2020 at 03:53 point
Actually I think this way is better (pre-recorded videos instead of live sessions) but as Ubuntourist said, if you told us that the video was pre-recorded we wouldn't have gotten up that early, so please consider telling us with any new changes. One more thing, the audio & video quality was very bad, please try fixing them. Thanks.
ubuntourist wrote 07/07/2020 at 13:18 point
So. The scheduled time of Tuesday 07/07 is more of a fantasy and I should just watch the YouTube videos, yes? Not anything "live" that I need to attend?
ahmed.asaleh2 wrote 07/07/2020 at 13:38 point
it looks to be that way
tyeth wrote 07/07/2020 at 15:21 point
I kind of thought the live event was a Q&A hour on zoom or silent watching the stream with moderated questions, but to be fair the youtube videos are sufficient and very good, I imagine the comments section will become a goldmine of info.
Anool Mahidharia wrote 07/07/2020 at 16:08 point
Hi All,
We decided to release just the pre-recorded video so everyone can go through it at their own pace. And then on Friday, 10th, we will have the "live" Q&A session where I'll be available.
If you don't want to wait until then, feel free to ask either here or on the project "chat" messaging.
AbdoHamdy wrote 07/05/2020 at 02:10 point
Will u upload the first week of the course on YouTube?
Anool Mahidharia wrote 07/05/2020 at 07:30 point
Yes
ahmed.asaleh2 wrote 06/26/2020 at 16:29 point
hello, I've spend about an hour trying to enroll to this course, can some one help please.
gary4132 wrote 06/25/2020 at 19:32 point
I'm a little confused about the signup process.  I'm assuming I go to the Eventbrite link and sign up there.  There are 4 dates listed and, the documentation states that I need to sign up for all four dates.  So, I guess these are the 4 individual weekly progressive courses?  And, if I need to sign up for all four, is there a way to aggregate them and checkout all four under one donation.  Very painful if you have to checkout each individually.
Anool Mahidharia wrote 06/26/2020 at 07:44 point
Sorry about that. I wasn't aware how the sign up process works, but I can send the feedback to the team that handles this at Hackaday.
ubuntourist wrote 06/23/2020 at 13:18 point
So. I've got the most of the prerequisites.set uop.. except I don't know where to unzip the three honkin' KiCad zip files. I'd rather not pollute anything put in place by dpkg.
Is there a common userland path where KiCad expects to find the unzipped footprints, packages3D and symbols?
If not, I'm inclined to try to make KiCad play like the other children and hang everything -- including the InteractiveHtmlBom plugin -- off of ~/.local/share/kicad/, adding a /footprints/, /symbols/ and /packages3D/ under that.
And then figure out how to set the environment variables or what-not to make KiCad find stuff there.
Anool Mahidharia wrote 06/23/2020 at 14:27 point
You can put them at any location, and then get KiCad to point to the appropriate path under PREFERENCES >> CONFIGURE PATHS
ubuntourist wrote 06/19/2020 at 10:08 point
Will there be any hardware requirements beyond the computer?
("Cuz I ain't got any." 😜)
Anool Mahidharia wrote 06/19/2020 at 14:36 point
Nope
Andrew Kowalczyk wrote 06/17/2020 at 20:14 point
Hi! Thank you so much for doing this, I ran an intro kicad course in my workplace and at my school, let me know if there's anything I can do to help!
Anool Mahidharia wrote 06/17/2020 at 21:06 point
Thanks, Andrew. I've posted images of what we'll cover in the class, so maybe you can go over them to see if you spot anything amiss. The plan is to build a Blinky using an ATtiny85. A Github repo will be added sometime soon.
ubuntourist wrote 06/16/2020 at 22:10 point
I have "some basic electronics and engineering knowledge" but not much...  VERY basic, I would say.
Anool Mahidharia wrote 06/17/2020 at 05:31 point
Shouldn't be a problem at all. Between the videos and instructions posted here, you'll be able to pick it up. And we're here to answer any questions if you get stuck.
