Hackaday.io Hackaday.io
Sign up Log in
Continuous Non-Invasive Blood Pressure ECG+PPG
This project is cuffless cNIBP research platform with ECG(two-electrode) and PPG
gcyGCY
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.3k views
7 comments
33 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 7
View Gallery
2.3k
7
33
24
Team (1)
  • gcyGCY
Join this project's team
  • cNIBP ECG+PPG
hardware
ongoing project
ecg ppg Blood pressure PULSE ARRIVAL TIME biomedical
This project was created on 06/19/2020 and last updated 6 years ago.
Description
This project is cuffless cNIBP research platform with ECG(two-electrode, without Right Leg Drive(RLD) ) and PPG(MAX3010x), the Pulse Arrival Time (PAT) using ECG and PPG signal, measure the time delay(∆t) between QRS-Complex of the ECG signal and any one systolic peak of the PPG signal.
Details
Components
  • 1 × STM32F405 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × MAX3010x
  • 1 × INA827
  • 1 × AD8669 or LM324
Log In/Sign up to comment
Sign up with Github
OR
sanskar329 wrote 03/31/2021 at 16:26 • point
How did you measure QRS complex?
GCY wrote 04/01/2021 at 04:51 • point
Use INA OP, and detect algorithm: https://github.com/GCY/wxECGAnalyzer
sgall17a wrote 06/24/2020 at 22:17 • point
Just looked up Max3010x =>  pulse oximeter to pick up systolic peak.  Amazing -   BP measurement without any actual pressure measurement.   Must admit I am a bit sceptical of the strength of this correlation with BP.  Just have to measure and see I suppose.  Even so,   the PWV might turn out to be a very valuable parameter in its own right
GCY wrote 06/25/2020 at 16:26 • point
 right, so PWV-BP method are for investigational use only.
sgall17a wrote 06/24/2020 at 22:03 • point
Brilliant idea to use QRS as indicator of the start of the wave at the heart.  The relationship between BP and PWT was new to me, so I followed your references - thanks.  It seems that the relationship is indirect via a change in arterial stiffness with BP and and increase in arterial blood volume via BP.  I assume arterial blood volume mostly depends on arterial geometry.  Arterial stiffness is probably an independent variable that may well have a clinical significance possibly as much as BP itself.   As a measure of BP, for instance as a replacement for ambulatory BP it seems to me that there are three factors:  1. A requirement for calibration.  2. How stable that calibration is (hours days weeks?).  3 Actual performance- ie how closely the measured value correlates with BP measurements.
Dan Maloney wrote 06/19/2020 at 22:59 • point
I never knew that was possible! I'd love to learn more about the theory behind this method. Any references?
GCY wrote 06/20/2020 at 05:43 • point
The theory based on pulse wave velocity : https://en.wikipedia.org/wiki/Pulse_wave_velocity
In general, pulse wave  arrival time and blood pressure is nonlinear relationship.
https://www.zdnet.com/article/blood-pressure-and-the-samsung-galaxy-watch-active-2-regular-monitoring-is-key-to-diagnosis/
A project completed for MIT's ProjX program in 2016 to develop a low-cost indoor 3D localization system using time-of-flight of sound waves.
Project Owner Contributor
Indoor 3D Localization with Sound
jake-wachlinJake Wachlin
This project shows how to synchronize live music and lights using DSP/DFT in real-time on ATtiny13 which offers only 64B RAM / 1024B FLASH.
ATtiny13 – dance lights with FFT
ukasz-podkalickiŁukasz Podkalicki
Official Hackaday Prize Entry
Measure teprature with a crystal occilator, long wave radio and an fpga.
Crystal temp
johannes-wgenJohannes Wågen
A simple software decoder for the 60kHz NPL time signal (aka MSF) accurate to a few tens of milliseconds.
MSF 60kHz decoder
tony-robinsonTony Robinson
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Continuous Non-Invasive Blood Pressure ECG+PPG", please tell us the reason.
Send message
Remove Member
