Running Processes
06/19/2020 at 22:01 • 0 commentsPID PPID USER STAT VSZ %MEM %CPU COMMAND
953 720 root S 17020 21.1 81.2 /dlna/twonkymediaserver -inifile /var/twonkymedia-server-default-huawei.ini
4936 1373 root R 2776 3.4 12.5 top -n 1
948 1 root S 85996107.0 0.0 call
748 1 root S 39444 49.1 0.0 xmlreporting
738 1 root S 37552 46.7 0.0 httpd
650 1 root S 37376 46.5 0.0 cms
662 1 root S 36760 45.7 0.0 atserver
669 1 root S 36548 45.5 0.0 ui_main
1062 1 root S 36524 45.4 0.0 upnp -D -L br0 -W rmnet0
918 1 root S 36476 45.4 0.0 /bin/wificonnect
890 888 root S 5364 6.6 0.0 /bin/hostapd_wps /tmp/hostapd.conf
1508 1323 root S N 4880 6.0 0.0 smbd -D
1323 1 root S N 4760 5.9 0.0 smbd -D
1327 1 root S 3604 4.4 0.0 nmbd -D
621 1 root S 2780 3.4 0.0 /usr/sbin/telnetd
1373 621 root S 2780 3.4 0.0 -ash
634 1 root S 2780 3.4 0.0 /sbin/getty ttyMSM2 115200 vt100
1 0 root S 2776 3.4 0.0 init
661 1 root S 1720 2.1 0.0 atproxy
832 1 root S 1716 2.1 0.0 /bin/dnsmasq -i br0 --conf-file=/var/dnsmasq.conf
730 1 root S 1668 2.0 0.0 atcsms
1064 1 root S 1636 2.0 0.0 lld2d br0
722 1 root S 1592 1.9 0.0 syswatch
633 1 root S 1588 1.9 0.0 mic
1115 1 root S 1584 1.9 0.0 dhcpc -i rmnet0 -I rmnet0
720 1 root S 1572 1.9 0.0 /dlna/twonkymedia -inifile /var/twonkymedia-server-default-huawei.ini
825 1 root S 1544 1.9 0.0 dhcps
372 1 root S < 1516 1.8 0.0 /sbin/udevd --daemon --debug
644 1 root S 1336 1.6 0.0 diag_switch /dev/ttyMSM0
888 1 root S 1332 1.6 0.0 /bin/hostapd_wps /tmp/hostapd.conf
864 2 root SW< 0 0.0 0.0 [ksdiorqd]
850 2 root SW< 0 0.0 0.0 [AR6K Async]
767 2 root SW< 0 0.0 0.0 [USB mass_storag]
5 2 root SW< 0 0.0 0.0 [events/0]
113 2 root SW< 0 0.0 0.0 [smd_tty]
4 2 root SW< 0 0.0 0.0 [watchdog/0]
315 2 root SW< 0 0.0 0.0 [mtdblockd]
140 2 root DW< 0 0.0 0.0 [rpcrouter]
91 2 root SW< 0 0.0 0.0 [kmmcd]
744 2 root SW< 0 0.0 0.0 [usb_work]
185 2 root SW 0 0.0 0.0 [pdflush]
645 2 root SW< 0 0.0 0.0 [mmcqd]
6 2 root SW< 0 0.0 0.0 [khelper]
150 2 root SW< 0 0.0 0.0 [ctl0]
3 2 root SW< 0 0.0 0.0 [ksoftirqd/0]
2 0 root SW< 0 0.0 0.0 [kthreadd]
10 2 root SW< 0 0.0 0.0 [suspend/0]
80 2 root SW< 0 0.0 0.0 [kblockd/0]
110 2 root SW< 0 0.0 0.0 [modem_notifier]
126 2 root SW< 0 0.0 0.0 [qmi]
133 2 root SW< 0 0.0 0.0 [nmea]
146 2 root SW< 0 0.0 0.0 [krpcserversd]
154 2 root SW< 0 0.0 0.0 [ctl1]
158 2 root SW< 0 0.0 0.0 [ctl2]
183 2 root SW 0 0.0 0.0 [pdflush]
186 2 root SW< 0 0.0 0.0 [kswapd0]
189 2 root SW< 0 0.0 0.0 [aio/0]
338 2 root SW< 0 0.0 0.0 [kondemand/0]
341 2 root SW< 0 0.0 0.0 [rpciod/0] -
/ # df
06/19/2020 at 21:46 • 0 comments
Filesystem 1k-blocks Used Available Use% Mounted on
rootfs 31516 31516 0 100% /
/dev/root 31516 31516 0 100% /
tmpfs 40124 4 40120 0% /dev
/dev/mtdblock0 6144 1760 4384 29% /mnt/flash
/dev/mtdblock1 41040 41040 0 100% /mnt/cdrom
/dev/mtdblock3 6464 6464 0 100% /mnt/www -
/etc/init.d/rcS script
06/19/2020 at 20:03 • 1 comment#!/bin/sh
# Copyright (C) 2008 QUALCOMM Incorporated. # All Rights Reserved. QUALCOMM Proprietary and Confidential.
################################################################################echo "rcS:::executing /etc/init.d/rcS script"
# re-establish ramfs file system:etc|var|mnt|
echo "establish ramfs file system:|tmp|etc|var|mnt|"
/bin/mount -f -t ramfs ramfs /tmp/bin/cp -rf /etc /tmp/
/bin/mount -n -t ramfs ramfs /etc
/bin/mv /tmp/etc/* /etc//bin/cp -rf /var /tmp/
/bin/mount -f -t ramfs ramfs /var
/bin/mv /tmp/var/* /var//bin/mount -f -t ramfs ramfs /mnt
echo "rcS:::mounting filesystems"
mount -a 2>/dev/null#echo "rcS:::mounting /prj/happyfeet"
#mkdir -p /prj/happyfeet
#mount -t nfs -n -o nolock,rsize=1024,wsize=1024 baskin:/vol/eng_asw_0032/happyfeet /prj/happyfeetecho "rcS:::executing /etc/rc.d scripts"
run-parts -a start /etc/rc.decho "rcS:::mounting flashfs"
mkdir -p /mnt/flash
mount -t yaffs2 /dev/mtdblock0 /mnt/flash# BB5D05399 s00163283, begin 2010/4/28
mkdir -p /mnt/dlna
# BB5D05399 s00163283, end 2010/4/28#echo "rcS:::rdate"
#/usr/sbin/rdate -s 129.6.15.29# Check CD-ROM Image
echo " Check CD-ROM"
mkdir /mnt/cdrom
mount -t iso9660 -o loop /dev/mtdblock1 /mnt/cdrom
#check webres img
mkdir /mnt/www
mount -f -t cramfs /dev/mtdblock3 /mnt/www
####BB5D05622 z00125912 begin
echo "rcS:::mounting pa_res"
mkdir -p /mnt/pa_res
mount -t cramfs /dev/mtdblock4 /mnt/pa_res
####BB5D05622 z00125912 end
# move the following into management.c for the feature:
# when 583x is being charged in power off state, the user shouldnot
# see the CDROM and port change
#if [ -f /mnt/cdrom/AutoRun.exe ]
#then
# echo " USB Default Dynamic Composition (0x1003)"
# /opt/qcom/bin/tests/usb_composition.sh 0x1003
# echo /dev/mtdblock1 > /sys/devices/platform/mass_storage/lun0/file
#else
# echo " USB Default Dynamic Composition (0x1E03)"
# /opt/qcom/bin/tests/usb_composition.sh 0x1E03
#fi# Run customer.rcS from /mnt/flash if [ -x /mnt/flash/customer.rcS ]; then
echo "rcS:::Executing /mnt/flash/customer.rcS"
fi# Starting Qcom DUN over HSUSB
echo"Starting DUN Bridge over HSUSB..."
#/opt/qcom/bin/./qcom_dun_hsusb.sh export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/qcom/libecho "rcS:::DONE Executing /etc/init.d/rcS Script"
# Nothing should live below this line!
cd /dev
mknod ttyHSUSB0 c 127 0
#/opt/qcom/bin/./port_bridge /dev/smd0 /dev/ttyHSUSB0 &cd /bin
#./ar6k_load_ap.sh
mic & -
All Commands Available
06/19/2020 at 19:53 • 0 comments/sbin #
arp
doc_loadbios
docfdisk
flash_erase
flash_eraseall
flash_info
flash_lock
flash_otp_dump
flash_otp_info
flash_unlock
flashcp
ftl_check
ftl_format
getty
ifconfig
ifdown
ifup
init
insmod
klogd
logread
lsmod
modprobe
mtd_debug
nanddump
nandtest
nandwrite
nftl_format
nftldump
pivot_root
recv_image
rfddump
rfdformat
rmmod
route
serve_image
setconsole
slattach
start-stop-daemon
sulogin
sumtool
switch_root
sysctl
syslogd
udevadm
udevd
udhcpc/bin #
addgroup
adduser
ar6000.ko
ar6000_sta.ko
ar6k-wps-oob.conf
ash
at
atcsms
athtcmd_ram.bin
athtestcmd
athwlan.bin.z77
athwlan_sta.bin.z77
atproxy
atserver
bbconfig
bmiloader
busybox
call
cat
chgrp
chmod
chown
cms
cp
cpio
data.patch.nopa.bin
data.patch.pa.bin
date
delgroup
deluser
device.bin
df
dhcpc
dhcps
diag_switch
dmesg
dnsmasq
dumpkmap
echo
eeprom.AR6002
egrep
factory
FALSE
fgrep
getopt
grep
gunzip
gzip
hostapd
hostapd_cli
hostapd_wps
hostname
httpd
ip
iperf
iptables
iwconfig
iwlist
iwpriv
kill
lld2d
ln
login
ls
mic
mkdir
mknod
mktemp
more
mount
mv
netstat
nice
nmbd
nopa.bin
nopaartagent
nvram
nvram_linux_test
pa.bin
paartagent
pidof
ping
ps
pwd
qmiserver
reboot
rm
rmdir
run-parts
sh
siproxd
sleep
smbd
smbpasswd
sntp
startsntp
stty
su
sync
syswatch
touch
TRUE
ui_main
umount
uname
upnp
usleep
wificonnect
wmiconfig
xmlreporting
xmltest zcat/usr/bin #
arping
basename
chvt
clear
cut
dc
deallocvt
dirname
env
expr
find
free
ftpget
ftpput
head
hexdump
hostid
id
ipcrm
ipcs
killall
less
logger
md5sum
nslookup
od
passwd
printf
readlink
renice
reset
seq
sort
strace
strings
test
tftp
time
top
tr
traceroute
tty
uptime
wc
wget
xargs/usr/sbin #
brctl
chroot
figlet
inetd
rdate
setlogcons -
cat /proc/mounts
06/19/2020 at 18:37 • 0 commentsrootfs / rootfs rw 0 0
/dev/root / cramfs ro 0 0
ramfs /tmp ramfs rw 0 0
ramfs /etc ramfs rw 0 0
ramfs /var ramfs rw 0 0
ramfs /mnt ramfs rw 0 0
none /debug debugfs rw 0 0
proc /proc proc rw 0 0
none /tmp ramfs rw 0 0
none /sys sysfs rw 0 0
none /var/log ramfs rw 0 0
none /var/run ramfs rw 0 0
none /var/lock ramfs rw 0 0
tmpfs /dev tmpfs rw,mode=755 0 0
devpts /dev/pts devpts rw,mode=600 0 0
/dev/mtdblock0 /mnt/flash yaffs2 rw 0 0
/dev/mtdblock1 /mnt/cdrom iso9660 ro 0 0
/dev/mtdblock3 /mnt/www cramfs ro 0 0
/dev/mmcblk0p2 /mnt/sd vfat rw,fmask=0022,dmask=0022,codepage=cp437,iocharset=utf8,shortname=mixed 0 0 -
cat /proc/version
06/19/2020 at 18:36 • 0 commentsLinux version 2.6.25 (bcm@localhost.localdomain) (gcc version 4.1.1 (CodeSourcery ARM Sourcery G++ 2006q3-26)) #1 PREEMPT Fri Sep 17 19:09:44 CST 2010
cat /proc/mtd
06/19/2020 at 18:33 • 0 commentsdev: size erasesize name
mtd0: 00600000 00020000 "0:EFS2APPS"
mtd1: 081c0000 00020000 "0:MMC"
mtd2: 02a00000 00020000 "0:APPS"
mtd3: 00e00000 00020000 "0:WEBSERVE" -
cat /proc/cpuinfo
06/19/2020 at 18:29 • 0 commentsProcessor : ARMv6-compatible processor rev 2 (v6l)
BogoMIPS : 382.56
Features : swp half thumb fastmult edsp java
CPU implementer : 0x41
CPU architecture: 6TEJ
CPU variant : 0x1
CPU part : 0xb36
CPU revision : 2
Cache type : write-back
Cache clean : cp15 c7 ops
Cache lockdown : format C
Cache format : Harvard
I size : 32768
I assoc : 4
I line length : 32
I sets : 256
D size : 32768
D assoc : 4
D line length : 32
D sets : 256Hardware : QCT SURF7X25
Revision : 0000
Serial : 0000000000000000
