11V1/2- M4 brass threaded inserts
12V3 Body assembly
13V3 Limit switch assembly
14V3 Limit switch holder - Body assembly
15Step 15
V3 Arms assembly
16V3 Encoder assembly (Increase the diameter of the small pulley to 6mm diameter)
17V3 Encoders - main body assembly
18V3 Large pulleys assembly (You have to put two brass threaded inserts on the vertical holes and thread an M4 screw on the radial hole)
19V3 Timing belts assembly
20V3 Arms - main body assembly
