V1.2.0
It worked as intended surprisingly:)
V1.3.1
Features
•X and Y CV for Joystick or other resistive pots
•Offset/Range Panel Knobs X/Y
•Offset Postive/Negative Voltage output LED Indication
The Redone schematic for witches brew module. LEDs are now driven linearly. The LEDS Brightness Linearly controlled By Converting Voltage Output to Current method *So It can Accurately Display the Voltage on the LED. Also redone most of the artwork with my improved art skills.
Also going to release the PCB files once finalized and maybe do some limited runs.
Neil Mundt
Alec Probst
Arnov Sharma
ElectronicABC
Jasper Sikken
Looks like a great rendition of the joystick controller idea, do you have any plans to release your PCB files, before I attempt to redraw the schematic in kicad...
