https://dai.ly/k2DZlQ8K6RZo4Cx3cEM
i turned a JLX Overdrive into a small lawnmover with high power. And this is how i have done it:
First of all the original remote control of the rc car was lost. So i took my old Fly Sky controller.
I read in the PWM signal from the receiver with an ESP32 board. Than some mathematics remap the signal to control the DC motors of the car with a monster motor shield.
The behaviour is similar to a tank with a separat left and right moving track.
After this i mounted a cheap brushless motor to the bottom of the car. The controller is direct connected to the receivers PWM signal so i can direct control the speed of the motor.
Durability of the Motor:
i use the system for two years now... if it fails i will remove it with another cheap one
Advantages of the BLDC Controller:
Normally they are used for drones. One characteristics is that they need a specific start procedure to run. This increases the safety. If the blade hit a obstacle the controller have a integrated overload detection (or speed detection) so it will stop direct to avoid damages. After running the start sequence it will direct start
Keith
Philip Ashmore
Any chance you can break out just the PWM read from the RC transmitter on the esp32? I'd like to use it but it's a bit above my skill level....
