Arcs instead of trapezoids
07/08/2020 at 02:59 • 0 comments -
10 mm sockets
07/07/2020 at 03:28 • 0 commentsSo the KSA-2 housing is 10mm thick. Looks like these connectors should work.
SSQ-105-02-T-D
https://www.digikey.com/product-detail/en/samtec-inc/SSQ-105-02-T-D/SAM1193-05-ND/1111259
The default KSA2 board is 0.8mm thick, but it looks like once the heat stakes are removed it could accomodate 1.2mm or maybe even 1.6mm thick boards.
Waiting on order from OSHPark
07/07/2020 at 01:17 • 0 commentsI ordered the first round of board from OSH Park. If they line up with the KSA-2 plastic box, I'll publish it on github.
Rob Ludwick
