13D Printing:
- 3D print all given 3D models.
- Print the screen layer in white PLA.
2Circuit Connections:
- Make all the connections as shown in circuit diagram.
- GND~-Ve
- Vin~5V~+Ve
- DataIn ~ Pin 2
- Also extend the power supply wires to last LED and connect, to prevent the voltage drop across the LEDs.
3Note:
- If you use Arduino board then you can only display animations,you cannot display time.
- If you use ESP8266 board then we can display time and other animations on the matrix.
4Assembly:
- Put all the LEDs in snake wise order.
- Assemble everything together.
- Solder the connector to Microcontroller board , the connector is taken from the other end of the LEDs line.
5Coding:
- Click here for codes
- For this matrix I have made three codes HexMatrix.ino ,clock1.ino and clock2.ino.
- HexMatrix code is the code for displaying animations on the matrix,it can run on any Microcontroller board.
- Clock and clock2 code only runs on ESP8266 boards.
HexMatrix.ino:
- Open the code given in Arduino IDE.
- Install the FastLED Library in Arduino IDE.
- Select the board type,port and upload the code.
Clock1 and Clock2 Codes:![]()
- Open the code in Arduino IDE.
- In this code we can change this values as per our color requirement
//Digit color values in RGB int r=255; int g=255; int b=255; //Background color values in RGB int br=0; int bg=20; int bb=10; - Enter the Wifi name and password
const char* ssid = "Wifi_Name"; const char* password = "Password"; - Enter the time zone of your country(India 5:30=5.5 similarly enter your time zone)
//Your time zone int timezone = -5.5 * 3600; - Select the board type as ESP8266,select the port and upload the code.
Apart from this we also have many other animations in the FastLED Examples.
Mukesh Sankhla
