It's only skin deep
08/01/2020 at 20:17 • 0 commentsBrian Cockfield wrote an article about this hack - thank you!
Some of the comments left were very useful and I appreciate them.
I had focused on what the CDC recommended, https://www.cdc.gov/coronavirus/2019-ncov/hcp/ppe-strategy/decontamination-reuse-respirators.html and the use UVGI. This was not universally accepted by WHO or CDC organization in other countries.
I set up a simple experiment with my UVC lamp, a UVC sensor with amplifier and oscilloscope. It has about 40dbV dynamic range to measure over.
I put a transparent glass slide over the UVC sensor and exposed it to UVC, it effectively blocked the UVC light. Both the N95 and KN95 mask blocked the UVC light. The cheap safeway mask did show UVC at -30dbV, a little got through.
If the mask is designed for filtration of smallest particles and the if the material is not transparent to UVC, the dense forest of filtering fibers isn't gong to allow UVC to pass through. It cannot sanitize what it cannot reach.
There is practical information on this in other applications when using UVC. Air-filtration and Water-filtration units that utilize UVC have prefilters whose function is to block the larger particles, The larger particles need to be removed as they will block UVC from reaching pathogens.
Again, thanks for the useful comments.
UVC vs Rubber, rubber loses
07/25/2020 at 18:55 • 0 commentsSo I found one con to using UVC for N95 mask.
UVC will cause rapid deterioration of rubber.
So one of my N95 masks had it's rubber strap snap when putting it on. The rubber had visibly changed and become brittle.
My other mask from the same pack but also not subject to the UV were still pliable.
Of course, this was after about 10 times in the UV Microwave and a few of the times, I didn't have the vent fan running.
At first I thought it was generating ozone, but going back to the datasheet, this tube is not supposed to create ozone. I did some research and UVC will cause photochemical change in plastics and rubber. (see FAQ at https://iuva.org/).
