Mycelium looks fine, clearly missing in some areas though.
Splitting of the casings was done over several days, in retrospect it should have been done faster. Once in sun, trapped moisture encouraged bacterial growth etc.
I took a solid bag, dried it and then sawed down the center.
The inside was not fully cured, but solid enough.
Unfortunately, despite it not being completely dry (and thus hopefully less absorbent) I coated the raw ride in resin and it soaked up a TON. I'll coat the nice side with just a single layer of resin and fiberglass. At-least this will be strong if it doesn't burst into flames.
Those chairs remind me a bit of one of the first articles I ever wrote for HaD: https://hackaday.com/2015/07/02/why-build-furniture-when-you-can-grow-it/
