Hyper Light Drifter Stat Tracker
The Stat Tracker is a portable battery powered device that keeps track of health, energy, and dashes for the HLD Table Top RPG.
What is it?
The Stat Tracker is a portable battery powered device that keeps track of health, energy, and dashes for the Hyper Light Drifter Table Top Role Playing Game. Although it was designed with Hyper Light Drifter in mind, it could be used in other table top games like Dungeons and Dragons.
Features:
- Tracks 40 points of Health and Energy and 10 points in Dashes
- Bright RGB leds for each icon
- Custom art in Hyper Light Drifter theme
- Unique Slim PCB sandwich construction with special icons for LED diffusion
- 3D Printed bottom housing
- 6 physical pcb buttons to add/subtract points
- 2 touch buttons for brightness control
- Customizable colour palettes including colourblind modes
- USB micro for charging
- 8 hours of battery life on default brightness and battery charge indicator icon
- Stats are saved on power off.
Stat Tracker in Rainbow Debug mode
PCB buttons side viewPCB Buttons side view
PCB buttons top/side viewPCB Buttons side view
Art: Battery icon and brightness up touch buttonArt: Battery icon and brightness up touch button
Art: Brightness down touch buttonArt: Brightness down touch button
Power Switch RightPower Switch and USB Micro
Matte Top PrototypeMatte Top Prototype
Middle Spacer BoardMiddle Spacer Board
Bottom Logic BoardBottom Logic Board
BatteryBattery
3D printed housing3D Printed Housing
Development
Shout out to Nick Poole for his talk on boggling the boardhouse https://www.youtube.com/watch?v=rAXmzt-_NZ4 where I use his PCB sandwich techniques for this project.
The first prototype has been completed and a second batch is soon to be ordered. Once everything is confirmed to be good for the second prototype then production of the Stat Tracker will be ready.
There will be articles on problems I have encountered and solved during the development of the stat tracker in the future.
Documentation
How to use
Increasing stats beyond the max will overfill the leds with a different colour giving a total of 40 points for Health and Energy and 10 in Dashes.
Battery Indicator
The Battery icon will change from Green to Red (on the default colour palette) based on battery life remaining. It will start flashing at low battery. The unit will auto shut off if the battery gets drained too much. If that occurs then a charge is required to turn it back on.
Charging
To charge: Simply plug in a USB micro cable to the USB port. The stat tracker will change to a battery display. The top row will show battery charge. Press any button to return to running mode and use the stat tracker while charging.
Colour Configuration
To enter colour configuration mode: Hold both touch buttons for a few seconds until you see it change modes. Press the dash buttons to change the colour palette. There are 3 colour palettes to choose from:
  • Default Hyper Light Drifter colours
  • Colourblind
  • Custom
In the custom colour palette mode: press the energy buttons to change the colour being edited and the health buttons to change the hue. You can also change the fully charged/discharged colours of the battery icon. Slow flashing batt icon: Fully charged colour. Fast flashing batt icon: Fully discharged colour. The battery icon will fade between the charged and discharged colours during normal operation.
To Save: Hold both Touch buttons for a few seconds.
  • Kickstarter has launched!
    Albert Phan • 10/06/2020 at 03:39 • 0 comments
    If you want to pick up one of my stat trackers then you can back me on kickstarter here: http://kck.st/36CJxMl
    Good news for fellow hackers as well: I have decided to open source my project so feel free to modify it for yourself and make your own top board art! Source files should be available after the campaign is complete.
  • Making PCB Pixel Art in Eagle
    Albert Phan • 09/03/2020 at 10:53 • 2 comments
    What you will need:
    - Eagle
    - Something to draw art (I use ms paint)
    - Built in eagle ulp to import bmp
    - Eagle Script to convert layers to specific art layers (can be found at the end of this page or download here)
    MS Paint Setup
    First off you will need to know how big your art will be and how many pixels per mm you will use.
    I used a pixel/mm size of 4 pixels/mm for my landscape art. At this resolution some of the 1 pixel size silkscreen does not turn out perfect but the other layers like copper and solder mask were fine.
    Make note of any things that the art needs to made around. For the stat tracker, the battery icon art had to be placed over the led underneath so you can see the light shine through the FR4.
    Make a new paint, resize to your required size and save as a 16 bit colour bitmap. Turn on the grid if you prefer.
View all 2 project logs
piONE.jp channel wrote 08/20/2020 at 18:52 • point
Thank you.
Richard Hogben wrote 08/20/2020 at 18:06 • point
Yeah really cool!
LovesTha wrote 08/20/2020 at 02:56 • point
I love this. Would really like to design a different top for use in mtg games. And maybe slightly different functionality for mtg commander games. Thinking of sharing the design files?
Albert Phan wrote 08/25/2020 at 18:47 • point
Haven't decided what I want to do with the design files yet but at the very least I will share the schematic and probably the top board info so you can make your own. Standby as I'm working on the next revision. What different functionality do you want to have?
LovesTha wrote 08/25/2020 at 23:15 • point
Sweet. Those along with the source code would allow for a healthy little community of different uses, just relying on you for everything except the top plate.
