An SD card is mandatory!
Your personal ID on this network is based on the SD card’s serial number (xx^xx+xx^xx = xxxx).
No MCU EEPROM, MCU serial number, or LoRa module serial number are used.
Every device is identical to one another until your SD card is inserted!
So, to erase all traces, keep the card off the device or destroy.
Scott Hasse
profdc9
Dylan Brophy
fjkraan
Yes. with ESP8266 or 32 it is possible to use web page instead of lcd to receive and send...
Try Heltek's LORA board. Very handy.
Here is code for you to start from.
https://github.com/Airrr17/LoRa_messenger/blob/master/LoRa-Heltek.ino
It's already receives and sends lora packets. Just add some web server to this code and enjoy :)
ops wrong thread.
