Added Bill of Materials and Some Instructions
08/23/2020 at 17:18 • 0 commentsAdded some instructions (to be finished soon), and (I hope) a full Bill of Materials. Minor Corrections/Additions to the STL/STEP/DXF zip file.
Build/Overall Design Video and Code Cleanup
08/22/2020 at 23:23 • 0 commentsAdded a build video in the project details!
Cleaned up the code a little bit:
--- took out some of the bits that were hanging out from other instruments).
--- Have also modularized the step-taking to be a function call to keep the forever loop looking a little cleaner.
Soon:
Plan on making the instructions a bit more detailed, and clearly defining the Bill of Materials. Also need to add in the step file/build files the little laser cut "clip" piece that helps hold the two halves of the base plate together.
Hello World
08/18/2020 at 07:47 • 0 commentsFirst build of this system - with some pre-build design iteration.
Features to add:
- Limit Switch
TheMixedSignal
