The ESP32-DevKitC-IVE module has additional flash and 8M SPIRAM. The available prebuilt Micropython firmware available does not utilize the doubled flash space ( 4M increased to 8M ).
Another important feature that needs some attention is the external antenna option. This board comes with both the on-board and external antenna disconnected. To protect the transmitter, one of these antenna should be selected and configured ( soldering! ) before the first power up of the module. The difficult part here - the tiny connection requires fine soldering skills at a minimum.
This process will increase the storage available in the filesystem from:
disk free: 1.972656 MB
memory free: 99.86%
to
disk free: 5.976563 MB
memory free: 99.86%
CarbonCycle
AVR
Jordan
Jarrett
microwavemont
