Should be expected, when probing bed, z axis moves up and down quickly which caused binding.
If you were able to only print in vase mode on a perfectly flat surface, you can get away with no binding issues. But to allow proper bed probing and z motion (z-hop, etc.), a second belt was added to support the opposite side of the bed.
Z-axis is stiff when attempting to rotate in the y direction.
Also very stiff when pushed in the Z direction on the supported side (held by the belt and stepper). However, the non-supported side does have flex. Its essentially acting as a cantilever bed as the carriage isn't fully constraining that end.
With about 10lb of force applied, Z on unsupported side will move up and down about 0.9mm.
- measure flex with unsupported side carriage removed (to simulate a cantilever bed). Another option might be to put dual carriages on the supported Z linear rail and use triangular support of the bed.
- extend 2020 to meet face of L bracket, see if it provides additional stiffness
80T pulley bought and some machining done on it: Two bearings inside the block on the left. 80T 6mm and 20T 10mm on 5mm shaft. Stepper motor on right mounted on 36mm standoffs.
By using our website and services, you expressly agree to the placement of our performance, functionality, and advertising cookies.
Learn More
