There are a few problems when it comes to building your own sonar from scratch.
- Get hold of the active element required for sonar: the transducer. Transducer material (usually piezo ceramics) is hard to get in small quantities. Usually they are made to order, and a few hundred dollar for a single batch is pretty common.
- Mechanical design of the transducer. Very little information on this is freely available online. Most companies keep the design process to themselves. And there is some design software available, but that's all commercial as well.
- A watertight housing for transducer and electronics. Not a trivial thing. My experience is that it is very hard to keep water out since it tends to creep through the smallest of holes. Extra complication here is that you will also need some way of connecting the electronics to the outside world.
- The electronics. Although that is not very complicated, it does require some specific components like transformer and tuning coils which are also not as easy to get at the average hobby-electronics store.
Cees Meijer
It looks like even the cheapest Teensy, the TeensyLC (yes,LC for Low Cost) might be sufficient for this task. But will it also be able to generate the transmit pulse and necessary control signals ? I will need a 512kHz burst, and some analogue ramp signal for the Time Variable Gain amplifier. And it turns out that this is not just possible, its also very simple.
Darren Winter
zaphod
Martin
Hey me again,
I tested a bit more and built a shield to drive and read ultrasonic transducers using the TI TUSS4470. It works quite well and is very easy to setup. I also tested with DIY transducers and it works! At least for a few meters. I'm currently working on another board to boost the transducers drive voltage and do the sampling with an STM32F103. Have you made progress on your echo sounder recently? Building a well tuned transducer seems to be a challenge. I decreased the output power a lot when, I wanted to embed the transducer inside cases. I collected most of the findings in this hackady article: https://hackaday.io/project/196793-a-diy-open-source-sonar
