28.12.2020 Voron Switchwire - Inductive Probe - Proximity Switch
12/28/2020 at 10:17 • 0 comments -
28.12.2020 - Voron Switchwire - Front and Rear Grill
12/28/2020 at 08:32 • 0 comments -
27.12.2020 - Voron Switchwire - Gantry - CoreXZ Belting
12/27/2020 at 12:00 • 0 commentsTimming Belt trianglelab GATES-LL-2GT 6mm
My Voron Switchwire Components List: https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components -
25.12.2020 - Voron Switchwire - X Axis - X Carriage Frame
12/25/2020 at 14:06 • 0 commentsMy Voron Switchwire Components List: https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
Voron Switchwire - X Axis - X Carriage Frame - PartsVoron Switchwire - X Axis - X Carriage Frame - Assembled Voron Switchwire - X Axis - X Carriage Frame - Assembled OMRON micro switch D2F soldered to 3 pins JST XH2.54 Female Connector Voron Switchwire - X Axis - X Carriage Frame - Back View Voron Switchwire - X Axis - X Carriage Frame - Front View -
24.12.2020 - Voron Switchwire - Gantry - X Axis Beam, X Bearing Block
12/24/2020 at 11:14 • 0 commentsMy Voron Switchwire Components List: https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
Voron Switchwire - X Bearing Block Voron Switchwire - X Beam with Left Side XZ Bearing Block Voron Switchwire - X Axis Beam - Top View Voron Switchwire - X Beam with Right Side XZ Bearing Block Voron Switchwire - X Axis Beam - Back View -
12.12.2020 - Voron Switchwire - Gantry - Z Bearing Blocks
12/12/2020 at 15:57 • 0 commentsVoron Switchwire - Right Side Z Bearing Block - Front View Voron Switchwire - Left Side Z Bearing Block - Front View Voron Switchwire - Left and Right Z Bearing Blocks - Back View Voron Switchwire - Left Side Z Bearing Block - Back View Voron Switchwire - Right Side Z Bearing Block - Back View (Igus Cable Chain Version) Voron Switchwire - Left and Right Z Bearing Blocks - Top View Brass Hot Melt Inset Nuts M3 X D5.0 X L4.0 Voron Switchwire - 3D Printed Left and Right Z Bearing Blocks
29.11.2020 - Voron Switchwire X-Axis, X-beam, X Linear Rail, XZ blocks
11/29/2020 at 15:41 • 0 commentsVoron Switchwire X-Axis, X-beam, X Linear Rail, XZ blocks - Component Voron Switchwire X-Axis, X-beam with Linear Rail and XZ blocks Voron Switchwire X-Axis, XZ block - Right Side Voron Switchwire X-Axis, XZ block - Left Side
28.11.2020 - Voron Switchwire Z-Axis Linear Rails
11/28/2020 at 13:08 • 0 commentsMy Voron Switchwire Components List: https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
Voron Switchwire Z-Axis Linear Rails - Parts Voron Switchwire Z-Axis Linear Rails with T-nuts Voron Switchwire Z-Axis Linear Rail - Right Side Voron Switchwire Z-Axis Linear Rail - Left Side Voron Switchwire Z carrige stop -
26.11.2020 - Voron Switchwire - Gantry - XZ Axis - Upper Idler Pulleys
11/26/2020 at 11:18 • 0 commentsComponents list: https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
Voron Switchwire - Gantry - XZ Axis - Upper Idler Pulleys - Front View Voron Switchwire - Gantry - XZ Axis - Upper Idler Pulleys - Side View Voron Switchwire - Gantry - XZ Axis - Upper Idler Pulley Block - Right Voron Switchwire - Gantry - XZ Axis - Upper Idler Pulley Block - Left Voron Switchwire - Gantry - XZ Axis - Upper Idler Pulley Blocks - Printed Parts Voron Switchwire - Gantry - XZ Axis - Upper Idler Pulley Blocks - Assembly
Idler Pulley Stacks: Spacer+Bearing+Bearing+Spacer+Spacer+Bearing+Bearing+Spacer
Bearings: Rain&Dew F695-2RS Bearing 5*13*4 mm ABEC-7 Flanged -
21.11.2020 - Voron Switchwire - Gantry - X and Z motors mount
11/21/2020 at 09:20 • 0 commentsMy Voron Switchwire Components List: https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
Voron Switchwire - Gantry - X and Z motors mount - Top view Voron Switchwire - Gantry - Z motor Voron Switchwire - Gantry - X motor
