15.11.2020 - Voron Switchwire X and Z Motor Drive Units
11/15/2020 at 17:17 • 0 commentsMy Voron Switchwire Components List: https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
02.11.2020 - Voron Switchwire Y-Axis Cable Chain Assembly
11/02/2020 at 15:41 • 0 commentsMy Voron Switchwire Parts list: https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
01.11.2020 - Voron Switchwire Y Axis Assembly
11/01/2020 at 13:23 • 0 comments -
30.10.2020 - Voron Switchwire Y-axis linear rail
10/30/2020 at 15:06 • 0 commentsComponents I have used you can find here: https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
11.10.2020 - Voron Switchwire Vibration Management
10/11/2020 at 16:09 • 0 comments4x Rubber Compressor Foot
4x Spring T-nut series 30xM5
4x BHCS M5x16
Links to suppliers you can find in components list section >>> https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
4x 3D ABS printed Washer 15x5.4x3mm. STL file >>> https://cdn.hackaday.io/files/1748107479071040/Rubber_Compressor_Foot_Washer_15x5.4x3mm.stl
07.10.2020 - Voron Switchwire Frame Finished
10/07/2020 at 15:45 • 0 comments -
05.10.2020 - Voron Switchwire Frame Assembly
10/05/2020 at 14:56 • 0 comments -
05.10.2020 - Prusa MK3 Y Carrier compatible with Voron Switchwire
10/05/2020 at 14:08 • 0 comments -
29.09.2020 - Voron Switchwire MISUMI frame kit.
09/30/2020 at 09:30 • 0 commentsFull set of pre-machined aluminium extrusions ready to assemble. Dimensions are matching the Prusa MK3 Y-Carriage and MK52 PCB heated bed.
26.09.2020 - Heat Bed and Linear Rails for my Voron Switchwire
09/26/2020 at 18:22 • 0 commentsI have received heat bed and liner rails.
