Version 2.0 of the board
01/08/2022 at 16:26 • 0 commentsA new version of the board a now available on Tindie. Schematic is the same but the breakout board is smaller to better fit your project.
Discount on SE050 Breakout Board
10/22/2020 at 20:47 • 0 commentsThere is a limited 20% discount (24$ instead of 30$) on the SE050 Breakout board. Don't miss it!
Using SE050 Breakout board as a PKCS11 token
10/22/2020 at 18:39 • 0 commentsNXP already provides all the stuff needed to use the SE050 as a pkcs11 token but documentation is not so easy to understand.
First of all you will have to install all the required packages on raspbian:
sudo apt-get update sudo apt-get install cmake cmake-curses-gui cmake-gui libssl-dev python3-pip libffi-dev sudo apt-get install gnutls-bin sudo apt-get install opensc opensc-pkcs11The if we consider that you have already downloaded and unzipped the Plug & Trust MW from NXP in the '~/se050_mw' directory (as explained in my previous post), you can type the following commands:
cd ~/se050_mw/simw-top/ python scripts/create_cmake_projects.py cd ~/se050_mw/simw-top_build/raspbian_native_se050_t1oi2c ccmake .A configuration window should appear, set the following parameters to the given values:
RTOS = Default mbedTLS_ALT = SSS HostCrypto = MBEDTLS
Launch the compilation and wait for a while (-_-) :
cmake --build . sudo make install sudo ldconfig /usr/local/lib export PKCS11_MODULE=/usr/local/lib/libsss_pkcs11.soNow your SE050 breakout board is ready to bu used as a PKCS11 token. if you list the available PKCS11 slots using pkcs11-tool from OpenSC, you should see the following output:
pkcs11-tool --module $PKCS11_MODULE --list-slots Available slots: Slot 0 (0x1): token label : SSS_PKCS11 token manufacturer : NXP token model : token flags : rng, token initialized hardware version : 3.1 firmware version : 2.16 serial num : pin min/max : 0/10In a next post, we will see how to use SE050 breakout board through pkcs11-tool.
Configuring the SE050 chip
10/04/2020 at 17:49 • 0 commentsNXP provides a simple tool intended to ease SE050 configuration. To install it type the following commands:
cd ~/se050_mw/simw-top/pycli/ sudo pip3 install -r requirements.txt sudo pip3 install -e src/Then you can use the 'ssscli' command to control/configure your SE050 secure element. For example:
#connect to se050 ssscli connect se050 t1oi2c none #get SE050 UID ssscli se05x uid #list objects on SE050 ssscli se05x readidlist #generate a 4096bits RSA key pair at address 0xf0000201 ssscli generate rsa 0xf0000201 4096 #sign a file touch foo ssscli sign 0xf0000201 foo foo_sig #verify file ssscli verify 0xf0000201 foo foo_sigSSCLI program provides other interesting features allowing to easily personalize your SE050 chip. Check the documentation provided with the NXP Plug & Trust MW for more information.
In the next post, i will explain how to use the SE050 chip as a standard PKCS11 token using OpenSC pkcs11-tool.
