Thermal Performance
11/21/2020 at 00:49 • 0 comments -
OSD Memory Consumption
11/20/2020 at 00:44 • 2 commentsPer the inquiry from @Aaron Covrig , here's the memory consumption over the past week:
The three series with nightly jumps are the mon instances, and the jumps are the mon services shutting down for the backup process.
Rebalance Still In Progress
11/13/2020 at 02:46 • 2 commentsThe OSD rebalance is still running, but it did free up enough space that I was able to finish migrating my media files. The total raw space currently in use is 66% of 54 TiB.
Added 10 more drives
10/27/2020 at 00:57 • 0 commentsI added the (hopefully) last 10 drives for this year. This brings the total raw capacity to 55 TiB and should be enough to finish migrating my data.
Ceph PG Autoscaler
10/24/2020 at 18:48 • 0 commentsIt looks like the PG autoscaler kicked in last night., and made the following changes:
- fs_ec_5_2: 64 pgs -> 256 pgs
The autobalancer should kick in later tonight or tomorrow to pull the OSDs back into alignment.
Rebalance Complete
10/20/2020 at 17:16 • 0 commentsThe cluster rebalance is finally complete. The final distribution also appears to be tighter than before the rebalance.
Rebalance Progress
10/13/2020 at 21:01 • 0 commentsThe rebalance is still progressing. It's particularly slower because I also changed the failure domain on my cephfs EC pool from OSD to HOST which increased the number of PGs that needed to be remapped. Aside from that, the rate of progression appears fairly typical. The two gaps in the plot are power outages caused by Hurricane Delta.
Added 8 more HDDs
10/07/2020 at 22:51 • 0 commentsI added 4 more RPi 4's and 8 2TB drives to bring the overall disk count to 20. The cluster rebalance looks like it's going to take a few days, but at least the I/O performance isn't too severely impacted.
Grafana Dashboard
09/29/2020 at 20:52 • 0 commentsI added a dashboard to my grafana server to show the telegraf data from the ceph cluster. You can see the disk io and cpu load from the cluster rebalancing from 10 osds to 12 osds.
