19.10.2020
10/19/2020 at 14:14 • 0 comments![]()
System tested on a bridge. This is the GPR image obtained for the bridge in the photo:
08.10.2020
10/08/2020 at 16:03 • 0 commentsSystem tested and works fine.
Antenna coupling is quite high. Would be nice placing the antennas at a bigger distance from each other, or using more directive antennas in order to reduce unwanted coupling.
