The main documentation for the project is contained in the README Markdown file at the GitHub repo, here is a direct link: GitHub README.md .
Metrics
| Description | Value |
| Wing Span | 800mm |
| Wing Area | 15.6dm^2 |
| Aspect Ratio | 4.1 |
| Airfoil (Root and Tip) | MH45 |
| Length | 520mm |
| Rotor Spacing | 315mm Circle |
| Lipoly Battery | 4s, 1300-1500mAh (~160g) |
| Motors (front) | 22xx or 23xx 2300-2600kV |
| Motor (rear) | 22xx or 23xx ~2000kV |
| Servos | HS-65HB/MG or eqv. |
| Flight Controller (size) | 30.50mm to 16.0mm Grid |
| Propellers (front) | 5050 to ~5249 |
| Propeller (rear) | 6030 to ~5249 |
Steve Carlson
Jocelyn Pietro
I can't figure out how to synchronize the engines when the vector of the front engines changes. Tell me where is the instruction on this issue? Thank you
