"Something" to be found in these logs:
- Nr. 1 (pictures! and how it's used)
- About the stencil jig
- Nr. 4 (had to add paste for one resistor that didn't get any paste at all)
- Nr. 7 (major breakthrough!!!)
- Nr. 12 (some problems here!)
- Nr. 19 (paste was a bit runny on the 360 Ohm resistor)
- First results after 19 boards
Full TOC:
- Nr. 2
- Nr. 3
- Nr. 5
- Nr. 6
- Nr. 8 (swapped two resistors, had to rework)
- Nr. 9 (slightly bad paste job)
- Nr. 10
- Nr. 11
- Nr. 13
- Nr. 14
- Nr. 15
- Nr. 16
- Nr. 17
- Nr. 18
- Nr. 20
- Nr. 21
- Nr. 22
- Nr. 23
- Nr. 24
- Nr. 25
- Nr. 26 (some pictures!)
- Nr. 27
- Nr. 28
- Nr. 29
- Nr. 30
- Nr. 31
- Nr. 32
- Nr. 33 (picture)
- Nr. 34
- Nr. 35
- Nr. 36
- Nr. 37
- Nr. 38
- Nr. 39 (one short on the USB connector)
- Nr. 40 (pictures!)
- Nr. 41
- Nr. 42
- Nr. 43
- Nr. 44
- Nr. 45
- Nr. 46
Christoph
zakqwy
leo60228
2bluesc
Your project got mentioned in the Macrofab Engineering Podcast #331. They took it almost serious, made me smile.
https://macrofab.com/blog/mep-ep331-the-pcb-plague/
