1Installing AppDaemon
This is an application-level program, not a system command or system feature. It is an add-on to your product software, and as such there is no global "apt-get install". You will need a copy of the source to modify for your needs.
Step 1: Copy the project to the /root directory.
> sudo su > cd /root > git clone https://github.com/ToolChainGang/AppDaemon.git
Step 2: Upgrade your system
The subdirectory "install" contains scripts to upgrade your system and install needed packages.
For proper installation, each script should be run multiple times, fixing errors as needed, until the output contains nothing but a list of "already have most recent version" messages.
(as root) > cd /root/AppDaemon/install > ./05-UpgradeInstall.sh Go get lunch, then rerun the script > ./05-UpgradeInstall.sh Verify that the output contains nothing but a list of "newest version" messages. > ./06-UpgradePerl.sh Go get dinner, then rerun the script > ./06-UpgradePerl.sh Verify that the output contains nothing but a list of "newest version" messages.
Step 3: Test your GPIO hardware
The install directory contains a testing app that uses the same GPIO logic as the AppDaemon.
Execute that app with your GPIO settings and verify that the config button hardware works, your LED blinks (if you use a config LED), and so on.
For example:
> GPIOTest --config-gpio=4 --led-gpio=19
Step 4: Install the test application
The install subdirectory contains a sample application (SampleApp) for testing.
Copy that application to the /home/pi directory, change the owner to pi:pi, then add a line to your /etc/rc.local file that invokes the AppDaemon with that file.
For example, put this in your /etc/rc.local file:
######################################################################################################################## # # Start the AppDaemon # set +e ConfigGPIO=4; # Config switch WPi07, Connector pin 7, GPIO (command) BCM 04 LEDGPIO=19; # Config LED WPi24, Connector pin 35, GPIO (command) BCM 19 nohup /root/AppDaemon/bin/AppDaemon --config-gpio=$ConfigGPIO --led-gpio=$LEDGPIO --user=pi /home/pi/SampleApp & #nohup /root/AppDaemon/bin/AppDaemon -v --config-gpio=$ConfigGPIO --led-gpio=$LEDGPIO --user=pi /home/pi/SampleApp & set -e
A sample rc.local file that does this is included with the project, so for a quick test you can do the following:
(as root) > cd /root/AppDaemon/install > cp SampleApp /home/pi/ > chown pi:pi /home/pi/SampleApp > cp /etc/rc.local /etc/rc.local.bak > cp rc.local.SAMPLE /etc/rc.local > reboot
Step 4: Connect the AppDaemon to your application
Once everything is running the /root/AppDaemon/install directory is no longer needed - you can delete it.
Change the link in rc.local to run your application instead of the SampleApp, and you're good to go.
The upgrade Perl script is 06 not 05 :)
Good catch, thanks. My unit tester found this and I corrected the GitHub file, but totally forgot about this one.
