More Flight Testing
01/18/2021 at 15:32 • 0 commentsRecently got back out to the field with my repaired Starship from the last video. I wanted to get a better 'feel' for the aircraft while in freefall so I could make more informed design changes for the next iteration. Unfortunately, the last flight ended in another crash (my fault), this time much more spectacular.
Starship Video
12/08/2020 at 20:25 • 0 commentsFound some free time today to get the video put together, so here it is now instead of tomorrow:
New Aero Surfaces and Paint
12/08/2020 at 17:22 • 0 commentsAfter some flying, I decided it was time to change out the Mk1-ish aero surfaces to something closer to SN8 and finally give it some paint. Flight video tomorrow!
Foam Body Panels & Landing Pad
12/02/2020 at 01:04 • 0 commentsHover testing is coming along nicely; in my free time I turned the back of my cutting board into a landing pad for the big flight (with skydive maneuver).
I had to add foam around the body to give the 3mm carbon body spars some more torsional stiffness (tail was wagging due to differential throttle for yaw control). Video soon! -
Starship Build Complete
11/24/2020 at 15:34 • 0 commentsJust finished up the hardware build on the Starship prototype. I had the CAD model pulled up to help cross-reference as the parts came together. Most everything went together nicely, I just need to make some minor changes to some of the printed parts for better tolerances/additional features. I still haven't figured out a plan for landing gear--it will most likely be passive, but for now I think I'll just grab it out of the air. Stay tuned for a build video and parts files!
Now on to hover testing, then the maneuver never attempted before: the skydive.
Avionics bulkhead:
3D Printed Parts
11/15/2020 at 01:02 • 0 commentsAll the parts are off the printer and cleaned up. Just waiting on some carbon rods to arrive in the mail to complete the structure's assembly.
Starship Design Underway
11/09/2020 at 15:48 • 0 commentsCAD design is finished--printing test parts now to verify tolerances, and parts are on order for the complete build.
