The two lines you might want to edit are the following:
# i2c bus (0 -- original Pi, 1 -- Rev 2 Pi)
I2CBUS = 1
# LCD Address
ADDRESS = 0x3f
after installing i2c-tools you can use
i2cdetect
to find your bus number, and then
i2cdetect -y 1
or whatever your bus number is, to find the address of your screen.
you can install the python smbus library with pip as well:
pip install smbus
The old VGA monitor identification interface is often overlooked. Here is a nice project that has some more information - and a PCB:
https://blog.atx.name/twilight-vga-i2c-breakout-board/
