The 7-inch display has 2 HDMI input ports and one AV input port. One HDMI port is dedicated to the connection of the Raspberry Pi, and the other is a common HDMI port for connecting to an external PC/game console/HDMI development board/HDMI set-top box. There is also an AV port that we use to connect an old AV microscope lens, and of course it can also connect other AV cameras/AV game consoles.Of course I can also connect a professional HDMI microscope to the HDMI port of the display.
aida64 uses the default interface refresh rate of 1 second, so its network consumption is very low, about 200KB~500KB per second, and the power consumption of the whole machine is about 4W.
ElecLab
Arnov Sharma
hurðaskellir
