Smarthome Panel Display for OpenHAB2 taken in an ikea cutting board
Finally...
I would say the big steps are taken. Everything is up an running an you can get the 3D parts on Thingiverse and as well as the software on github . Enjoy!
After some "dry exercises" it was finally time: The Raspberry got its new task as a "Smart Home Central"...
Here are some steps I did to get everything up and running:
After this it was time to read out some temperature data from the BMP280:
The possibilities of the Raspberry Pis invite you to make the panel a bit smarter. I still have quite a few WS2812b LEDs available, as well as a BOSCH BMP280 sensor with which I can still realize a temperature measurement.
So having all the components together I cut out the cut-out for the display with a jig saw. After this I started designing all the needed parts with fusion 360 and printed them.
This is beautiful! I will definitely add it to my to-do list.
Thank you for sharing it with the community.
Excellent!! Nice design. Like the Ikea breadboard. Gives a whole new meaning to "breadboarding a project"......
This looks spectacular, great job! I love the whole thing, but the cleat for hanging it is a really great touch.
Everybody knows that mechanical key boards are just better ;-)
Thanks a lot! I have just added another log. Now also the SW and the 3D parts are open source.
This is really beautiful! Need to build it. Could you share the wiring of the power supply?
