***There is an update for this project using OP25 which works better. See the main projects page.***
Or
https://hackaday.io/project/181529-raspberry-pi-op25
Just for reference on the LCD Screen:
3.5" touch screen:
Part# MP13501
https://www.waveshare.com/3.5inch-rpi-lcd-a.htm
Commands to terminal
sudo ./LCD35-show
/\ will turn the screen on every time powered on
sudo ./LCD-hdmi
/\ will turn off the LCD screen and revert back to HDMI
-Rotation-
cd LCD-show/
sudo ./rotate.sh 90
DSD 1.7 is available at:
https://github.com/szechyjs/dsd
see:
https://github-wiki-see.page/m/szechyjs/dsd/wiki/Installation
There are several rtl-sdr dongles available in several places:
Or:
Is the one that I use.
***There is an update for this project using OP25. See the main projects page.***
Or
I've used a script from pihome with success to shrink RPi images:
https://github.com/mikerr/pihome/blob/master/resizeimage.pl
