Hackaday.io Hackaday.io
Sign up Log in
ATtiny13A TinyPocketRadio
FM Stereo Radio based on ATtiny13A and RDA5807MP
stefan-wagnerStefan Wagner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.2k views
4 comments
14 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 4
View Gallery
1.2k
4
14
27
Team (1)
  • stefan-wagnerStefan Wagner
Join this project's team
  • Project Files (Github)
  • Project Files (EasyEDA)
completed project
hardware
attiny attiny13 ATtiny13a avr arduino mp5807 fm radio audio pcb
This project was created on 11/29/2020 and last updated 2 years ago.
Description
TinyPocketRadio is a simple FM stereo radio based on ATtiny13A and RDA5807MP. It's powered by a CR2032 coin cell battery and can drive 32 Ohm headphones via the 3.5 mm audio plug. The board size is 38 x 23 mm. It has a power switch and three buttons: "Channel+", Volume-" and "Volume+ ".Description and project files: https://github.com/wagiminator/ATtiny13-TinyPocketRadio
Details
Log In/Sign up to comment
Sign up with Github
OR
niuyingxian wrote 11/30/2020 at 22:00 • point
Can you share the whole project? Thank you
Stefan Wagner wrote 12/01/2020 at 16:42 • point
Hi, please click on the link "Project Files (Github)" somewhere on the page.
vlk wrote 11/29/2020 at 21:33 • point
very nice project, you could reduce buttons to two, short press volume+/- and long press ch+ ch-, because if you have many radio stations around then ch- is sometimes nice to have
Stefan Wagner wrote 12/01/2020 at 16:46 • point
Thank you. In fact, there are three buttons because three pins were still unused on the ATtiny ;-) Of course, you can change the button behavior in the software.
The world's first gluten free bread-board
Project Owner Contributor
Universal Prototyping Board
goat-industriesGOAT INDUSTRIES
WLED-compatible board in the form factor of an common 801640 LiPo disposable vape battery.
WLED Pixie
kyleKyle
PHONO-EQ-100: a compact, cased MM phono preamp designed to run on a Li-Po battery, over 180 hours per charge, charged over USB-C.
Tiny Battery Phono Preamp for MM, USB-C Charged
elehobicaElehobica
A compact head amp for MC cartridges, ahead of our tiny MM phono preamp. Simple discrete circuit on a single Li-Po cell, no boost converter
Low Noise Battery Head Amp for MC cartridges
elehobicaElehobica
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ATtiny13A TinyPocketRadio", please tell us the reason.
Send message
Remove Member
