Yet another 555 timer built from discrete components.
x-zip-compressed - 472.90 kB - 12/10/2020 at 01:31
Standard Tesselated Geometry - 679.38 kB - 12/10/2020 at 01:31
Standard Tesselated Geometry - 161.12 kB - 12/10/2020 at 01:31
View all 18 components
Solder the brass nuts to the pads on the back side of the board. Use flux and a high power iron, or a heated plate, or a heat gun or a reflow oven.
Solder the remaining components according their position. Every component value is labeled in the board.
Install the legs using the M3 bolts and nuts.
View all 4 instructions
MrQ
Kaloyan Stefanov
Menga
drewrisinger
Yes, delete it Cancel
You are about to report the project "Discrete 555 Timer", please tell us the reason.
