1Brass Nuts Soldering
Solder the brass nuts to the pads on the back side of the board. Use flux and a high power iron, or a heated plate, or a heat gun or a reflow oven.
2Solder the rest of the components
Solder the remaining components according their position. Every component value is labeled in the board.
3Install the legs
Install the legs using the M3 bolts and nuts.
4Install the knobs
Install the knobs with the M4 bolts.
