As a complete newbee I try to rebuild Manoel daSilvas Project.
DSKY Alarms.pagesx-iwork-pages-sffpages - 90.52 kB - 12/16/2020 at 13:44 |
OpenGorton-Regular.otfOpenType Font File - 8.62 kB - 12/16/2020 at 13:44 |
OpenGorton-Bold.otfOpenType Font File - 8.70 kB - 12/16/2020 at 13:43 |
DSKY Nextion Front v5.jpgJPEG Image - 179.23 kB - 12/16/2020 at 13:33 |
DSKY Indicator new v2.stlStandard Tesselated Geometry - 27.62 kB - 12/16/2020 at 13:33 |
...sometimes I got distracted... ;-)
In this case I was very intrigued by the keyboard design from garak (Bernd). He posted some pictures in Manoels project and I started the redesign in Fusion. After I was already in the middle he was so kind to share his construction files and additional tips for the build. Thx a lot Bernd!!
So I started the build and today I saw the keyboard working for the first time.. It took some time since (payed) work kicked in...
Here are some impressions:
And finally:
(Due to my (non existing) solder skills its not stable yet and I‘m still searching for loose contacts (Wackelkontakte)
Next step will be the matrix perfboard for the keyboard and fitting the new unit in the DSKY.
Exact for the end of the year the keyboard is now functional and is connected with the Raspi.
It was a learning journey about serial connection and a looong bugfixing with the physical keyboard. Turns out that my soldering skills need improvement (actually non existent ;-) ) , the understanding of the pins on the arduino micro needed some research. On the way ‚ I have built a new keyboard, messed it up (cols and rows), only to use to first version in the end.
During the „frustration time“ I worked on key cap prototypes:
VERB: Font Gorton, original key cap with simple inlay, acryl colour - clear visible frame, letters not separated enough, colour is sinking in
NOUN: Font Open Gorton, shorter key cap with overlapping inlay, acryl colour - colour is sinking in
KEYREL: Font Open Gorton, original key cap with printed letter inlay (white) filled with black sugro - not bad, but not enough contrast
„9“ : Font Open Gorton, original key cap with simple inlay, filled with white sugro - a little bit on the „bold“ side but if I solve this in Fusion360 this could be the solution for „non-backlight“ keyboards.
Next step: connect the display with the Raspi
Merry X-Mas y‘all!
For the first time the front of the DSKY is closed. I‘ve finished Keyboard v1.0. Althrough I‘m not completely happy it‘s a step ;-)
...some sanding needed but I‘m pretty sure that it will not be the last version...
First attempt was to create an „inlay“ for the keycaps provided by Manoel. For this I used the the font Gorton, converted the text in Inkscape in a path and included it as *.svg than in Fusion360. Than filled the text in the inlay with acyl colour.
Since this left me with a clearly visible frame from the keycap, I designed my own (the top section 1mm shorter) and used the space for an inlay which is covering the complete surface, also this time I used the font OpenGorton which I think better match the original:
Shortcomings: The fonts for the ciphers are too big. The acyl colour is sinking in. I‘ve ordered some sugro to give it a try.
Since I (...and I saw Manoel found it also ;-) ) stumbled over a video in youtube from Patrick Rigney I‘m very intrigued by his keycap design since it would also allow backlighting. Maybe I‘ll try to go that way...
I found Manoel daSilvas project and I was asking myself if I could rebuild it as a complete newbee. (and I mean it: everything is new to me!)
So I started with the programming part. Tried to make the the virtualAGC work on an raspi.. OK, no success so far, but I got some experiences in coding in VisiualStudiocode. Then I tried my luck with dsky_keyboard_arduino and dsky_display (2 messages while compiling) . Still no success but I‘m learning and will get there. First litte step forward: I was able to put the layout on the NextionDisplay... Now we‘re talking :-)
Meanwhile my 3D printer (Ender5) has arrived and I started to print the parts.
Soldered the keyboard matrix
Finished 3D parts except for the Backhousing
Assembled the HW with heatsink brass threads
Since the gaps between the housing and the display- und the indicator case came out quite big in my printing I have re-designed them from the scratch. Fusion360 (for the first time) : This lets me appreciate Manoels efforts to create all the files from the drawings even more. Now they are not original any more but they fit neatly.
Designed and printed a stand for the DSKY
WIP : Soldering the perfboards for the indicators
WIP : combining the raspi with the arduinos (with testcode)
...also I‘m thinking of ways to design keycaps.. I know I‘m not the first one ;-)
Hello Stefan,
Greetings from Germany. I also want to print your keycaps. Would you mind to publish the files? Then I would try to print them with FDM.
Hi Bernd, check it out... Took some time but I‘m getting there. Thanks for your help! I guess that you‘ll find other parts from your design here in the future ;-) but for now I‘ll concentrate to make the thing work... Stay tuned!
Wow, that's a complicated one for your first project but it already looks great!
Hi! Congrats on the first prints! It's really coming along nicely :)
Owen Trueblood
Sergio Costas
Benchoff
Nick Poole
I'm curious, what are the keyswitches used here?
Also, it would be good to provide links to the original material -- I don't know who this Garak/Bernd is, or Manoel deSilva, but I know that I like what I see so far ;) and I'd love to see the original.
