• Motor & movement
    yuh • 01/30/2021 at 15:49 • 0 comments
    Lay-out work for the motor attachment on the Y axis
    Motor mount cut out of 2mm aluminium
    Let paint dry
    I don’t have the real blue paint that most machinists use, but a permanent marker (and some sanding afterwards) will do the job!
    X axis motor mount
    Y axis motor mount paintjob
    For holding the nut in place
    Nut holder for the y axis: bent and painted
    Wooden bit will keep the nut from spinning
    X axis motor mount
    Z axis motor mount
    Z axis motor mount installed
    I upgraded the mount for the bolt
    Also the X nut holder is improved
    Z movement
  • Varia
    yuh • 12/27/2020 at 11:14 • 0 comments
    Base plate of 1.8 mm thick plywood, here is where I will be mounting everything on
    This is a test
    Column attachment to the baseplate
    Drilled and countersunk underside
    Overkill? I think not!Normally I am a big (big!!) fan of Torx drive screws, and I have a lot of Torx head screws in storage, about 1700, but I didn’t buy thick and long ones. I had to use 5x80 mm Philips head screws instead…
  • Column
    yuh • 12/27/2020 at 11:11 • 0 comments
    Column made of plywood
    The 5 layers of 1,8mm thick plywood
    Upright image of the wooden column
    The template I used for marking and cutting out the column.
    Z axis, identical to the y axis
    Z axis is attached
    The same brackets as on the XY table
    New Z axis motor mount, now the whole axis will be identical to the Y axis (left to right)This will be beneficial for the captive nut
  • XY table
    yuh • 12/27/2020 at 11:07 • 0 comments
    XY table top view
    Side view
    Stoppers for the linear rails and not all screws are used yet because I will have to undo them anyways in a bit
    Bottom view
    Base rails to the base plank
    Added trough bolts for more squareness and stiffness
    Drilled and tapped
    Table is mounted much more secure, I added a larger diameter for the fasteners connecting to the linear bearings, so my imperfections can pass trough without any issues of alignment
    Of course i still have to tighten the nut, but I do that when I am sure that I like it this way
