Motor & movement
01/30/2021 at 15:49 • 0 commentsLay-out work for the motor attachment on the Y axis
Motor mount cut out of 2mm aluminium
Let paint dry
I don’t have the real blue paint that most machinists use, but a permanent marker (and some sanding afterwards) will do the job!
X axis motor mount
Y axis motor mount paintjob
For holding the nut in place
Nut holder for the y axis: bent and painted
Wooden bit will keep the nut from spinning
X axis motor mount
Z axis motor mount
Z axis motor mount installed
I upgraded the mount for the bolt
Also the X nut holder is improved
Z movement
Varia
12/27/2020 at 11:14 • 0 commentsBase plate of 1.8 mm thick plywood, here is where I will be mounting everything on
This is a test
Column attachment to the baseplate
Drilled and countersunk underside
Overkill? I think not! Normally I am a big (big!!) fan of Torx drive screws, and I have a lot of Torx head screws in storage, about 1700, but I didn’t buy thick and long ones. I had to use 5x80 mm Philips head screws instead…
Column
12/27/2020 at 11:11 • 0 commentsColumn made of plywood
The 5 layers of 1,8mm thick plywood
Upright image of the wooden column
The template I used for marking and cutting out the column.
Z axis, identical to the y axis
Z axis is attached
The same brackets as on the XY table
New Z axis motor mount, now the whole axis will be identical to the Y axis (left to right) This will be beneficial for the captive nut
XY table
12/27/2020 at 11:07 • 0 commentsXY table top view
Side view
Stoppers for the linear rails and not all screws are used yet because I will have to undo them anyways in a bit
Bottom view
Base rails to the base plank
Added trough bolts for more squareness and stiffness
Drilled and tapped
Table is mounted much more secure, I added a larger diameter for the fasteners connecting to the linear bearings, so my imperfections can pass trough without any issues of alignment
Of course i still have to tighten the nut, but I do that when I am sure that I like it this way
