OSC Calibrator and High-Voltage Fuse Resetter for 8-Pin ATtinys based on ATtiny84
Oh yes, you're right. I corrected the BOM. Thank you for the hint!
Hi Stefan, thanks for this great product. As the 0603 SMD parts are to small for me to solder them by hand, I am thinking of let them assembling by a PCB company. The basic costs are quite high and it makes no price difference to let assemble a few more.
Is it ok for you, when I order 5 or 10 pcs (I need one or two) and give the rest of the boards to interested people at roughly cost price?
Thanks Markus
Can you please tell what is the USB pwr connector part number, or reference?
Thanks!
https://aliexpress.com/wholesale?SearchText=micro+usb+2pin+dip
Great one, I could use it. I made minor changes to my board: jumper 5v and omitted the 3.3v regulator and its 2 capacitors. I haven't needed to use any of my ATtiny x5 in low voltage, always used 5v
Thank you. Many of my projects are powered directly by batteries. That's why 3.3V makes sense for me.
Unfortunately, I don't have the time to make and sell a meaningful amount of boards.
the SS-12D10L5 switch is not the correct size. It is to big. Might want to recheck your BOM I have 10 switches that are useless now.
