Hackaday.io Hackaday.io
Sign up Log in
ATtiny84 Tiny Calibrator
OSC Calibrator and High-Voltage Fuse Resetter for 8-Pin ATtinys based on ATtiny84
stefan-wagnerStefan Wagner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.6k views
10 comments
19 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 10
View Gallery
1.6k
10
19
18
Team (1)
  • stefan-wagnerStefan Wagner
Join this project's team
  • Project Files (Github)
  • Project Files (EasyEDA)
hardware
ongoing project
attiny attiny13 attiny85 Attiny84 avr oled programmer fuse attiny44 arduino pcb
This project was created on 12/27/2020 and last updated a year ago.
Description
Because the 8-pin ATtinys only have a few GPIO pins available, they are usually operated without an external clock. The internal oscillator does a good job in most applications, but when it comes to precise timing, its +/-10% accuracy is often insufficient. Fortunately, the oscillator can be calibrated, increasing its accuracy to +/-2% or better. There are a few ways to perform this manual calibration, but several steps are required. The TinyCalibrator does this fully automatically by a push of a button. In order to make the device more versatile, a high-voltage fuse resetter was also integrated, with which "bricked" ATtinys can be reset to the factory state.Description and project files: https://github.com/wagiminator/ATtiny84-TinyCalibrator
Details
Log In/Sign up to comment
Sign up with Github
OR
apollogibbons wrote 06/05/2021 at 21:37 • point
the SS-12D10L5 switch is not the correct size. It is to big. Might want to recheck your BOM I have 10 switches that are useless now.
Stefan Wagner wrote 06/08/2021 at 16:56 • point
Oh yes, you're right. I corrected the BOM. Thank you for the hint!
fuchsiv wrote 05/17/2021 at 20:59 • point
Hi Stefan, thanks for this great product. As the 0603 SMD parts are to small for me to solder them by hand, I am thinking of let them assembling by a PCB company. The basic costs are quite high and it makes no price difference to let assemble a few more.
Is it ok for you, when I order 5 or 10 pcs (I need one or two) and give the rest of the boards to interested people at roughly cost price?
Thanks Markus
Stefan Wagner wrote 05/18/2021 at 18:35 • point
No problem!
k1200s wrote 03/13/2021 at 00:33 • point
Can you please tell what is the USB pwr connector part number, or reference?
Thanks!
Stefan Wagner wrote 03/13/2021 at 19:24 • point
https://aliexpress.com/wholesale?SearchText=micro+usb+2pin+dip
killua wrote 01/20/2021 at 00:33 • point
Great one, I could use it.  I made minor changes to my board: jumper 5v and omitted the 3.3v regulator and its 2 capacitors.  I haven't needed to use any of my ATtiny x5 in low voltage, always used 5v
Stefan Wagner wrote 01/21/2021 at 16:26 • point
Thank you. Many of my projects are powered directly by batteries. That's why 3.3V makes sense for me.
medpixman wrote 12/30/2020 at 14:28 • point
Can you sell them?
Stefan Wagner wrote 12/30/2020 at 17:02 • point
Unfortunately, I don't have the time to make and sell a meaningful amount of boards.
What, you're using a 555? I could've done that with a microcontroller!
Project Owner Contributor
ATTiny555
shranav-palakurthiShranav Palakurthi
How to make 500W Step up converter
utsourceproductutsourceproduct
The ATtiny1604 is a microcontroller from Microchip’s tinyAVR series, and programming it can be done using the UPDI (Unified Program and Debu
Design ATtiny1604 UPDI HV Programmer
electronicsworkshopselectronicsworkshops
I present two new designs with an improved 555 timer core in 20-pin packages
New 555 Timers with 20-pins
adrian-freedAdrian Freed
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "ATtiny84 Tiny Calibrator", please tell us the reason.
Send message
Remove Member
