Top enclosure TM1637.3mf
PrusaSlicer 3D-print project file for the top part of the enclosure. It's meant to fit snugly to the bottom part with little friction. The project specifies supports, which are necessary because the front hole is closed.
3mf -
30.81 kB -
02/05/2021 at 22:12
Download
Bottom enclosure TM1637.3mf
PrusaSlicer 3D-print project file for the bottom part of the enclosure, with supports for a vertically-mounted TM1637-based display from Robotdyn. It requires four M3 hex nuts that will be embedded in the print. The printer will pause at the right time so they can be inserted.
3mf -
50.10 kB -
02/05/2021 at 22:11
Download
Bottom enclosure.3mf
PrusaSlicer 3D-print project file for the bottom part of the enclosure. It requires four M3 hex nuts that will be embedded in the print. The printer will pause at the right time so they can be inserted.
3mf -
47.29 kB -
12/31/2020 at 10:34
Download
Top enclosure.3mf
3mf -
29.71 kB -
01/01/2021 at 20:56
Download
schematic.pdf
PDF of the schematic.
Adobe Portable Document Format -
172.90 kB -
12/31/2020 at 10:11
Preview
board.sch
The schematic in Eagle. The design is split into 3 pages: the part relevant for this project is in page 1, the other two were for an attempt to add an audio processor and digital VU meter.
sch -
1.02 MB -
12/31/2020 at 10:06
Download
board.brd
The board in Eagle. Everything in page 2 and 3 of the schematic can be left unpopulated.
brd -
214.51 kB -
12/31/2020 at 10:06
Download
